how to diagnose smoke on start up?
recently purchased a 83 sc that had the engine recently gone thru (tensioner upgrade,3.2 kit,complete rebuild maybe 40,000 miles ago .smokes alot on start up and no other time,
Old 10-10-2009, 10:10 PM
Regis turd ab user
What's alot, and how long does it last?
Most of our cars have that symptom.
Old 10-10-2009, 10:31 PM
Senior Advisor
James Brown's Avatar
mine does but it smells like burning gas, sometimes a lot not so much if I let the engine idle a few minutes before shutting it down. if it goes away soon after start, that's normal for a car with higher mileage. If it still smokes at normal operating temp and/or on hard acceleration, it might need new valve guides or P/C rings.
08 Cayenne Turbo
Old 10-10-2009, 11:37 PM
Wavey's Avatar
Let it idle for 30-60 seconds before shutting down. You can watch the oil level gauge move up as the oil is pumped out of the crankcase and into the tank. You should get a lot less or no smoke on startup if you always do this.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 10-11-2009, 06:28 AM
jevvy's Avatar
Check you plugs for an oily one, you might have a blocked injector or faulty spark on one cylinder making it run weak and oily.
'89 3.2/3.6 coupe
Old 10-11-2009, 08:40 AM
If it is cool where you are you can get a fair amount of steam from condensate and it can look like smoke.
It is normal for a pancake motor to puff a little smoke on start up which you might smell for a bit.
If you are blowing a lot of blue smoke, I would check the plugs as noted as you will be burning a lot of oil with acceleration and on throttle lift also.
Old 10-11-2009, 09:05 AM
Check the oil level...most liklely too much oil. a little smokey start up is normal however.
brant giere
2005 996 cup
1991 964 euro cup (Larbre #28- race
1987 carrera 3.2-street/de car
1962 Austin Healey 3000
Old 10-11-2009, 09:14 AM
Santa Clarita, Ca.
I've even noticed a difference with oil type. My car will smoke a bit more on startup if I use synthetic. Regular Brad Penn and no smoke on start.
Old 10-11-2009, 10:20 AM
Wavey's Avatar
Weird - exactly the opposite of my experience. Brad Penn smoked way more than M1 in my car.
Old 10-11-2009, 10:33 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Porsche Crest Really Weird...
When I got the car, 4 months ago, following the PO oil change with 20/50 synthetic, it use to leak like a sieve... but not much smoking on start-up.
I did the top up with Brad Pen and the leak stop but the White Smoke at start-up seem to have increase.
When it smoke there is also water drops coming out of the mufflers pipes kind of indicating that it's condensation from somewhere.
Who Will Live... Will See
Old 10-11-2009, 03:01 PM
AutoBahned
RWebb's Avatar
smoke color?
how many days sitting when it smokes on startup?
Old 10-11-2009, 05:12 PM
Was this a recent development or has it been doing this all along?
Old 10-11-2009, 05:16 PM
Senior Advisor
wow water out the tailpipe, that sounds like a head gasket!! any antifreeze in that water??
08 Cayenne Turbo
Old 10-11-2009, 05:28 PM
Does it smell like oil and linger in the air before dissipating? Condensation does not smell nor does it linger like oil.
Old 10-13-2009, 09:13 AM
(the shotguns)
berettafan's Avatar
shoot a vid for us.
wavey that idle thing is pretty interesting, never heard that before. would this practice possibly cause the moving parts to be slower to get oil at startup?
Old 10-13-2009, 01:35 PM
Wavey's Avatar
I thought that was pretty much common knowledge but maybe not? It's worked like a charm for me. I doubt that there's any change at startup - it just gets the excess oil out of the crankcase so it cant sit in the bottom of the cylinders and seep past the rings overnight. I'm sure there's still oil everywhere it needs to be on startup. I use M1 so I don't worry too much about it with the synthetic anyway. On the rare occasion I'm in a hurry or I forget to let it idle, I'll get the normal startup smoke. But otherwise, VERY little or none.
But porsche83's issue sounds like normal condensation to me, especially if he's doing short trips. Or it could be a little condensation and a little oil if he's not using the idle method.
Old 10-13-2009, 01:56 PM
mca mca is offline
mca's Avatar
If it is strictly white smoke, couldn't it be fuel?
I get this every so often on my fresh motor. Smells like sulfur and is white. Dissipates immediately.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 10-13-2009, 02:31 PM
Tincanguy's Avatar
+1, Wavey! My 88 Targa never smokes on startup IF I let it idle for 30-60 seconds before shutdown. Although this may not work for very high mileage cars, it works perfectly for my 95K mile Carrera
1988 Carrera Targa, Guard's Red
1959 356A - long gone
1960 356B - long gone
1978 SC Targa, GP White - Accident - Totaled 2006 (T-boned by a nut on drugs)
2003 VW V6 Passat Wagon
Old 10-13-2009, 03:21 PM
JJ 911SC's Avatar
Porsche Crest Antifreeze in the water would be miracoulous...
Since its Air Cooled... lol
Old 10-13-2009, 03:27 PM
JJ 911SC's Avatar
Porsche Crest Nope...
No smell and it dissipate with a couple of feet pf the pipes...
Old 10-13-2009, 03:31 PM
