Question about changing Weber/PMO main jets.
My 2.7 has PMO carbs set up for the street with 140 mains. The car runs perfectly. It has been suggested that there might be a bit more power available with 145 or even 150 mains for track use.
Question: can I make this fairly small change to bigger mains without changing three or four other jets/adjustments at the same time or am I pretty much getting into a major retune?
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Generally speaking,.......main jets are sized to venturi selection while factoring CR and displacement.
You can change MJ's without adjusting/tuning anything unless its a big big difference in jet sizing. Remember, you can use Air Corrector jets to fine tune the AFR's at WOT near the RPM peak.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Thanks Steve. Are you suggesting fooling with the air corrector jets as an option to a bigger main?
If its slightly lean or rich at peak RPM, then an A/C change does the trick without affecting mid-range.
Unless you have numbers for your AFR's, you are wasting your time. I have a wideband O2 guage in my car and have found that my car was running richer than I thought. I've had to go to smaller main jets to get a good mixture. (12.5-13.2 at WOT). A change of mains from 150 to 155 results in about .7 change to AFR on my 3.0 SC motor. I also found that a track temp of 65 degrees results in .5 leaner than a track temp of 90 degrees.
-Andy
72 Carrera RS replica, Spec 911 racer |
Senior Advisor
afr is critical, one on each cylinder would be best but you can get by with 2, one on each side.
08 Cayenne Turbo |
Thanks all, very helpful.
I'd like to resurrect this thread to ask at what rpm the air correction jets might be expected to make a difference. Steve says peak rpm, but surely a change would show up earlier. 5k? 6k? Thanks.
I have found that the air correction jets make smaller changes than the main jets. I have also found that either one only shifts the "curve" up or down. It doesn't change the shape of the curve. Maybe the emulsion tubes can change the shape but I suspect not. I just find what I think is the best compromise. It ends up at 13.2 AFR for most of the RPM range and goes rich at low and high RPM. As rich as 11.0 at 7200 and 4000.
-Andy
Science is NOT optional
Are you measuring AFR's on both banks or individually?
PCA member since 1993 |
For the moment just one. Thanks.
