help - front bearing race part welded? to spindle - what now?
On the track the handling was funny and then heard a noise.
The right front outside wheel bearing failed.
We have spent a good part of the afternoon, cutting into beer drinking time now, trying to get the outside race piece off.
Here is a picture, we have tried all sorts of things, pipe wrench, heat, pullers, cutting with dremel/etc. that thing is not moving.
Is it welded to the spindle? Do we give up and assume we will need a new Boge spindle or do we go to Harbor Freight and get more air tools? Any ideas appriciated.
Sold: 1989 3.2 coupe, 112k miles
Old 05-12-2012, 03:21 PM
Party Member
viejopatron's Avatar
Man, that's f-ed up.
Can you fashion a slid hammer using the puller?
Gary
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 05-12-2012, 03:34 PM
That wouldn't happen to be a left M strut would it?
Old 05-12-2012, 03:55 PM
I don't know because I don't know what a left M strut is.
Old 05-12-2012, 04:47 PM
AutoBahned
RWebb's Avatar
try edm
Old 05-12-2012, 05:17 PM
Banned
Wouldn't an air hammer make short work of that?
Old 05-12-2012, 05:21 PM
Cory M's Avatar
Have you tried an air hammer/chisel?
Even if you get it off the spindle may be junk, any scratches and nicks could crack later on, also the spindle diameter is probably way off from the original spec due to all the wear.
Old 05-12-2012, 05:22 PM
That's what we thinking now. Posted before beer time and we where not thinking straight. Need new/used spindle.
Old 05-13-2012, 08:20 AM
I've got a pair late Boge struts (86-89) if you're interested. PM me if you want to discuss.
Old 05-13-2012, 08:38 AM
ivangene's Avatar
my guess is that if you manage to get it off, what you will be left with is a spindle in need of replacing....save yourself some time and just get a anew one.....
the bearing surface is most likely goobered up
how hot is hot? MAP gas should get it red hot....some form of puller would be my tool of choice
Ed M
86' Coupe
Old 05-13-2012, 09:12 AM
done a few roadside repairs with worse looking races than that
we only had big hammers and cold chisels, we cut a groove like you have with a chisel and then use the chisel sideways to your groove and hit it hard in the direction of rotation, really stubborn ones required one guy to hold the chisel (with a big pliers or rag) and one guy to hammer it, it will split and come off
worst one I was involved in was an overloaded 1 ton truck with duallies in the middle of nowhere, only way we knew the bearing failed was the inner tire got so hot from the bearing welding itself that it blew out with a huge bang.
that truck ran 10 more overload years on the same chiseled up axle
Old 05-13-2012, 11:30 AM
Thanks, seems like something we should look at, I've pointed out your post to the owner, we'll see what he wants to do. Can lead a horse to water....
Old 05-13-2012, 12:38 PM
point taken, didn't get it that hot but were using map, already broke one puller
Old 05-13-2012, 01:40 PM
Dremel a parallel slot on the other side of the race -- 180 from the one in your pic?
Old 05-13-2012, 02:30 PM
Update - owner got an air chisel attempting to get the race peeled off. Nothing doing. Apparently for the most part it welded itself to the spindle. Now looking to find replacement spindle. Spindle says BOGE on it.
Old 05-21-2012, 07:51 AM
What year car? What side is bad? You will need a replacement strut housing.
Old 05-21-2012, 08:51 AM
I think it is an 88 and right (passenger) side.
A person above has what looks like the correct struts.
I don't know how to tell which is the exact model needed.
I can post other markings found on the strut assuming the owner has not already got the replacement part lined up.
Thanks for the note.
Old 05-21-2012, 09:04 AM
