Go-Kart Mozart
JAR0023's Avatar
No start issue on our road trip!!!!!!!!
Just had a no start situation. Stopped for a break. Came out power but no start. Car lit right up on 5 or 6th attempt. Next stop El Paso and on to Boerne. About to check voltage but seems more like a starter ground issue. Will check in later for advice.
J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 05-25-2012, 01:58 PM
porwolf's Avatar
J
In worst case have car towed to the nearest gas station with a garage. Put it on a lift and check all the electrical connections to the starter motor. Of course first check the battery connections and capacity. I once had a similar condition on an older Landcruiser where the battery grounding strap was corroded internally to next to nothing.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-25-2012, 02:16 PM
Go-Kart Mozart
JAR0023's Avatar
Battery is old. Gonna find a lift in las cruces. Alt. Working fine. No date on battery. Didn't want to shut it down again in middle of nowhere.
I have to own up to leaving light on for half hour during stop. Not sure that could do it. Maybe. When it finally lit the starter spun fast and strong.
J
Sent from my PB99400 using Tapatalk 2
86 Carrera
H. L. Mencken
Old 05-25-2012, 02:45 PM
Does the starter spin and the engine not start, or does nothing happen when you hit the key?
You did not mention what year 911 you have. On my 85 Carrera the starter will get heat soaked on trips but never just around town. Once it is heat soaked it just locks up. I can wait 20 minutes and it will cool down enough to start. Squirting water on it helps but is a pain to do. You will need to replace the starter or have it rebuilt if that is the problem.
Old 05-25-2012, 02:57 PM
Go-Kart Mozart
JAR0023's Avatar
86. Nothing for 7-8 tries then bam. Fired right up. It's hot. I10 new Mexico.
J
86 Carrera
H. L. Mencken
Old 05-25-2012, 03:05 PM
Go-Kart Mozart
JAR0023's Avatar
Loose nut behind the wheel I guess. Stopped in las cruces. Alt fine. Bat fine. Connections at starter fine. Starts no issue. I did leave lights on earlier. Won't do that again.
Onward.
J
86 Carrera
H. L. Mencken
Old 05-25-2012, 03:57 PM
Detached Member
Hugh R's Avatar
If you haven't heard,never disconnect the battery with it running you will immediately destroy the alternator
Good luck
Hugh
Old 05-25-2012, 04:01 PM
muck-raker
kidrock's Avatar
I will PM you my cell #. Let me know if you have any issues between Cruces and El Paso. I'm at work right now but I could be there if you get in a pinch.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-25-2012, 04:16 PM
Go-Kart Mozart
JAR0023's Avatar
Thanks Hugh. Don't think I knew that.
Forgot to mention I did put a full turn of the wrench on each battery post. The were loose.
Just stopped for fuel restarted no issue. 25.5 mpg.
J
86 Carrera
H. L. Mencken
Old 05-25-2012, 04:20 PM
porwolf's Avatar
Glad you got going again! Scary stuff on the open road.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-25-2012, 04:25 PM
well if its a dead spot in your starter just have your mate hold the key in the start position while you give the starter a good smack with a hammer. that should crank it over. same deal with a sketchy fuel pump
Old 05-25-2012, 05:44 PM
what car?
Rick
88 Cab
Old 05-25-2012, 09:20 PM
Go-Kart Mozart
JAR0023's Avatar
It's back.
Well, I must have stopped and restarted the car 8-10 times this evening between fueling, eating and trying to find a hotel in west TX. Finally gave up and pushed through to Boerne (outside San Antonio). Parked car up front, then spent 25 minutes checking in, getting my daughter in bed and unloading the car. Went back out to move the car and nothing. It's not in the fire lane so desk clerc said it's safe there til in the morning. There's a Ford dealer right around the corner. Here's hoping they are open tomorrow so we can see underneath. My kingdom for a real jack and jack stands right now.
Eta. 86 Carrera
J
Old 05-26-2012, 01:51 AM
Lorenfb's Avatar
"If you haven't heard,never disconnect the battery with it running you will immediately destroy the alternator"
Not correct! It's possible though to damage some electronics if the alternator
over-voltages the electrical system the result of a bad regulator.
There's a good possibility that commutator or the brushes are worn in the starter
causing intermittent cranking. You need to have someone listen for the starter
solenoid to engage (click) but the engine not crank. That would indicate that
the starter motor is the problem.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-26-2012, 05:37 AM
my comment was not a joke that is really what you should do
Old 05-26-2012, 06:46 AM
Lorenfb's Avatar
"my comment was not a joke that is really what you should do"
Yes, it does work sometimes, especially if it's a stuck solenoid.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 05-26-2012, 06:56 AM
pete3799's Avatar
Check and clean the ground at the front of the trans. to the body.
Mine would some times just click like a dead battery. Cleaned the ground and it's been fine for 3 years now.
Pete
79 911SC RoW
Old 05-26-2012, 07:22 AM
the "hammer smack" works when the brushes are worn short, the springs are having difficulty making the brushes make good contact, the smack helps them.
Old 05-26-2012, 08:11 AM
park on a hill.
Rick
88 Cab
Old 05-26-2012, 08:37 AM
Go-Kart Mozart
JAR0023's Avatar
Originally Posted by rick-l View Post
park on a hill.
LOL. Thanks for the laugh. Problem is I don't think there is a hill in Houston, Tx.
Old 05-26-2012, 01:20 PM
