Rolling car without axles?
Does anyone know if it is okay to roll the car around with the axles removed (engine and trans also), or will it destroy the rear wheel bearings? How about towing the car a couple of blocks?
Thanks.
89 911 Silver Ann.
Old 05-29-2012, 08:41 AM
Spiderman
Jesse16's Avatar
My opinion is you can do it no problem. The Drive shaft provides no support at all "in/out" for the bearing. It is a very stout bearing.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 05-29-2012, 09:05 AM
you need to slip in the outer stubs and tighten the nut or the double inner races will spread and possibly damage the bearing
206 637 4071
Old 05-29-2012, 09:23 AM
Spiderman
Jesse16's Avatar
Double inner races, had no idea. Never heard of such a thing, wonder why thats done ? Good to learn something.
Old 05-29-2012, 09:26 AM
bearings
As JW said, even moving around the shop can spread them.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-29-2012, 09:36 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The driveshaft must be in for the 85.5-up cars because the outboard stub is part of the axle assembly- it's welded to the CV joint. The earlier cars that have the bolted CVs on both ends can be rolled around without the driveshafts. This is because the stub stays in place when the axle shaft is removed.
Kevin L
'86 Carrera "Larry"
Old 05-29-2012, 01:41 PM
Okay. Thanks for the info.
89 911 Silver Ann.
Old 05-30-2012, 07:28 AM
