Author of "101 Projects"
Testing Heater Relay?
A customer sent me this question, I have to run to a dentist appt right now, so I thought I would ask the forums to help him out:
Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Your full-on-all-the-****-time heat might be caused by an open circuit at the sensor in the windshield frame above the rear view mirror (if you have one there.) If so, remove the sensor and make sure it is making contact with the plug-on wire behind it. If the plug is loose giving an open circuit, the autoheat goes full-on.
Happens to me occasionally on the freeway in July at 98 degrees with the A/C running -- the heat comes on to the max. Pull over, re-make the connection, motor on happily and cooly. |
1984 911 Targa - "Sabine"
Paul,
First question, is it auto heat or manual levers? If auto heat, I can direct you to a long post which I initiated on a "system not working" issue. My problem was linked to BOTH the engine fan motor as well as the relay. There are also some tests you can do in order to test the 12 point harness (relay is a completely different matter). The rear engine blower on mine will initiate at all times when the heater is on, as well as if the engine starts heating up. If you're getting full heat in the cabin, that normally assumes that the flapper boxes between the heat exchangers and the floor ducting below the doors are closed, forcing the heat into the cabin. This can be due to either the servo not releasing, seized cables, or flapper box problems. I started what is now a rather long thread, but has excellent responses and tests (although it is based on the Auto-Heat, but the basics less the parts between the seats I believe are identical. You can PM me if you wish as well, and I'll help as best I can. I have an '84. Auto Heat Query
Skip 1984 (RoW) 911 3.2 Li Carrera - "Sabine" 2011 Cayenne S |
