Inari77S
Guest
Posts: n/a
Question Part number help?
I'm looking for the short hose that goes between the defroster duct and the heater box(?), the one that the cables from the dashboard connect to that controls intake of fresh air vs. heat and floor vs. defrost.
And:
the drain hose that runs from the bottom of the air intake box through the trunk floor. My old one was ribbed plastic, about 1" diameter.
Can someone help with sources?
Thanks,
Old 05-10-2002, 03:49 AM
From the '74-'77 factory parts catalog: 901.571.345.32 for the short hose piece between the control box and the nozzle with flattened end; two required per car. The drain hose is 911.571.223.00 (for lefthand drive cars). These are likely dealer parts but Pelican can probably get them for you. If you want used (I wouldn't as these type of used parts may be in as bad a shape or worse than your old ones) I'd check with Parts Heaven. Cheers, Jim
Old 05-10-2002, 08:36 AM
According to the Porsche dealer ADP database,
901-571-345-32 is available in the Reno NV warehouse
911-571-223-00 is not showing available.
Maybe Wayne here at PP can special order for you.
Old 05-10-2002, 09:07 AM
Inari77S
Guest
Posts: n/a
How 'bout that, Wayne? Can you get these?
Old 05-10-2002, 10:05 AM
keitho64's Avatar
Count me in on this thread. I need the hoses for the heat exchanger to the flapper box on chassis. In looking on Pelican I found this: Description Heater Hose, Heat Exchanger to Heater flapper box on chassis (12 inch Length), 911 (1965-89). part number 902-211-921-20. Does anyone if this includes two hoses or one? The picture shows two but I want to make sure what I need to order.
I also need the hoses that go from the top shrouds to the heat exchanger and am assuming they are on Pelican as: Description Heater Hose, Heat Exchanger to Engine Shroud (18 inch Length), 911 (1965-74) A-211-194-00. Same question as above, do I need a quantity of two or does this include both.
Last question is the same as the beginning of this thread. Where can I find the hoses that go from the passenger compartment footwell area to the divertver valve and then from diverter valve to air box as well as defroster ducts. I cannot seem to find them on Pelican.
I want to order all of these to complete my project but do not know where to turn for the defroster hoses.
Any ideas are welcome.
Wayne - is all of this available here? If so can you point us to the right spot?
Keitho64
05 GTO
00 911 C2
64 Corvair
Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles
Old 05-10-2002, 11:05 AM
