major air box issue
Too many folks helping to change plug wires. Got off one hole in the distributor cap. Went to start and blew up the air box. How bad of a situation do I have?
Old 05-31-2012, 02:28 PM
new air box with flapper valve
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-31-2012, 02:30 PM
Scott R's Avatar
Have any other work that could be done while the engine is out?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-31-2012, 02:38 PM
so the engine has to come out to replace the air box?
Old 05-31-2012, 03:08 PM
Flat Six
Flat Six's Avatar
I have a DME car so no personal experience, but maybe this will help:
Remove my CIS while in car
Good luck
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 05-31-2012, 03:27 PM
Scott R's Avatar
No, not technically, you can do it with a partial drop. However if you want to do a really good job replacing the various gaskets and sealing it up, it sure is a lot easier. I've done this numerous times both ways, and anymore I just prefer the engine drop so I can do the valves and etc at the same time. That's why I was wondering if you had any other work to be done.
Also one more thing, you will likely replace the rubber boots to the intake runners as well, each is held on by two clamps and they must be aligned and tightened so that the runners sit flush on the heads. Why is this an issue? Well you can't reach the back clamps inside the car to adjust the runners if you need to. (well I can't anyway)
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-31-2012, 04:40 PM
+1 on what Scott R said.
Are you sure your air box is blown?
If it is, you can glue it instead of buying a new one. I just did this using 3M Scotchguard DP8010 glue as recommended on another thread on this forum. I've also had a glue called Manley 907 suggested to me by a mechanic who races a 914. I didn't want to spend almost 500 smackers on a new airbox and pop off valve. It has worked perfectly. But be careful to use the right glue because normal glue won't adhere to the airbox plastic.
I'd say do it with the engine out - probably easier that way all told.
Old 06-01-2012, 08:13 PM
... But you do have to fix it or your engine will never run right.
Old 06-01-2012, 08:20 PM
I'm assembling my CIS on my engine (which is out of the car and on a stand) and I'm having "fun" reaching everything with full access. I'm sure it's possible, but I think very difficult to access everything if this was still in the car...
Old 06-01-2012, 09:44 PM
Diss Member
Quicksilver's Avatar
If you watch the parts forum you will see a metal airbox every once in a while. Might be worth a search.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-02-2012, 06:46 AM
I had very good luck with the 81 style air box with the internal tubing. I never had an explosion with it installed and never needed a flapper valve either. But it only works if you have the late style CIS with the aux air regulator (no hand throttle).
Old 06-02-2012, 10:08 AM
