Remove my CIS while in car
For anyone who has considered removing the cis to get to the breather gasket etc and believes that they have to drop the engine or do a partial drop, i want to let you know that you can remove the CIS system while in the car, without too much aggravation.
Blew an airbox, the box was old and fatigued and cracked so i had to replace it. I have mid rise lift but i did not want to drop the engine and did not want to do a partial drop here is how i did it. DISCONNECT THE BATTERY! 1. Remove the air filter cover. 2. Remove the duct work for the oa fan. 3. remove the oa fan. 4. On the drivers side at the front of the motor there is a brace that holds the one side of the air box. it is connected to the accelerator plate that is fastened to the engine with a 13mm nut. It requires a 13 mm socket,, remove it. 5. on the passenger side on the front most intake runner there is a 13 mm bolt that holds another brace. remove it. 6. Remove all intake runner nuts. 12mm socket required. 7. Using a large flat head screwdriver (i used a brake adjustment tool), Pry out the injector on the back most driver's side intake runner. 8. Loosen the rubber clamp screws on this runner. If you cant get to them then loosen any of the rubber clamp screws that you can get too. 9. With the clamp screws loose or removed, wrestle the intake runner out of the sleeve and off of the bolts. 10. Do all of the drivers side runners first. Plug the intake holes with paper towels. 11. Remove the throttle linkage connector. 12. remove the accelerator plate spring. 13. remove the 5mm allen bolts for the wur. 14. ,oosen the rubber boot clamps that connect the fd to the throttle. Remove the throttle housing 4-5mm bolts. 15. remove the fuel distributor 6-5mm bolts with springs, i use a small magnet to keep to not loose anything. 16. I left all fuel lines connected and removed a vacuum line from the throttle body and covered the fd with plactic and moved it back. 17. With the drivers side runners off, and all hoses and vacuum lines disconnected from the air box, you should be able lift up the air box and runners up and out of the car. 18. Get new: throttle body o-ring, intake gaskets, oil switch, thermostat o-ring, o-rings for the injectors, o-rings for the injector sleeves, new injector sleeves, new breather hose, new over-flow hose (under the air box that on mine runs through the fire wall and down), new fuel distributor gasket. That is all i can think of to get. 19. Remove the injector by grinding off the 3 tabs on the intake runners. drive the old injector sleeves out, mine came out easily. Put the new injector sleeves in and make new tabs (stakes) using a pin drift (this was the hardest thing for me to do). After you clean everthing and put in new gaskets etc. Re-install is fairly straight forward but: 1. put on the passenger side front most runner first do not connect to the intake. 2. Put a new o-ring on the injector (soak the o-rings in gasoline for 5 minutes). I used and crescent wrench and some wood blocks to press the injector into the sleeve, use a plactic knife filed down flat and about 1/4 inch wide to help push the o-ring into place. I needed to do this on 2 injectors. 3. Do the same to the middle one, then the back one. put in place each time an tighten the clamps,, liift up to get access and put the next one on and so on. 3. Put on the new intake gaskets. 4. after you have the passenger side intake runners on and fuel injectors installed. then start with the MIDDLE intake runner on the drivers side (it is lowest). 5 then the front one and so on. 6. takes time but it is doable, the injector sleeve stake-on tabs and tightening the passenger side front most intake runner bolts was the hardest..
1975 911S Targa Silver Anniversary Edition Last edited by 47silver; 11-15-2009 at 09:50 PM.. Reason: correction |
Eye of the Toiger
u cant its and engine out job
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Almost Banned Once
- Peter |
Eye of the Toiger
how'd you do it??
Almost Banned Once
Pretty much as above. It's hard but it can be done.
Having a mirror about 4 inches wide and 2 inches high helps. If you place it at the firewall it and it gives you a better look at the rear nuts securing the air box. I never liked the idea of a partial engine drop. Either full drop or leave it.
- Peter |
i have done it ... I only had to lower the engine about 3 inches at the back .. took me 90 minutes from getting the jack to having the whole CIS on the workbench .. it is not about technical ability , it is more about being organized...
in my mind this is the right way to do it and you can replace all the runner gaskets and make sure the rubber sleeves aren't stressed.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I have done it without lowering the engine. Just pop the hood and start removing stuff.
Not my car, another Pelican user. It isn't easy, but it certainly can be done. |
Should read removed my cis instead of remove.
The removal is not that difficult, I did not lower the engine at all, it is a pain but if you take your time and follow my outline, (think drivers side runners first and loosen the braces in the back of the box, then you can do it. The first time it took me about 3 hours to remove it, but I think i can remove it in less than 2 the next time.
It is a puzzle to put back together but most parts only can be installed in one manner so it makes it fairly simple to do. If there is a special tool to make the stake-ons (tabs) for the injector sleeves i would purchase or make one as that is the only problem i encountered that caused me any concern. I was afraid of breaking the injector sleeves when making new stake-on tabs with a drift pin punch. I did not want to have exposed gasoline in the garage so i did not remove any of the fuel lines or injectors.
1975 911S Targa Silver Anniversary Edition |
my back says the only way to do it is to drop the engine
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
Well, Youre dealing with a 75, piece of cake, try the same on a 80-83, its a completely different ball of wax.
Bruce |
i had to replace the oil thermo stat. i considered both options and opted for an engine drop. glad i did. i did some other stuff while it was out. valve adjustment is much easier for one. i also corrected cam timing which was advanced by PO, not on purpose. i suspected it was off when i bought it.
Designer King
The Porschemonkey and I did it on my car (77 w/80 engine and CIS) this spring. I don't know if it is easier or faster than by dropping the engine because I haven't done it by doing the drop. He suggested it and I feel everything went fine.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
We all know the Porschemonkey is superhuman.
Designer King
Yeah, but what up w/ that banana breath?
BTW, didn't the monk have a 90C4, Paul?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-16-2009 at 12:39 PM.. |
I would have to agree w/ Flat6Packon the later SC's. There is no way in hell to get all that stuff off w/o dropping the motor somewhat. I just replaced my 83SC airbox using the partial drop method and it must of taken me a month of Sundays. Not one nut, bolt, screw or clamp came off easily-every fastener fought me every inch of the way! It was truly agony. I only went with the partial drop because of limited space issues and I didn't want to get into rebuilding everything under the car like I know I would have been tempted to do if the motor was out.
Next time it all gets dropped! |
In six minutes it takes you to put your the car on jack-stands, put the jack under the engine and loosen the mounting bolts, to lower it 4-6 inches. You don't have to unplug anything or do anything special, it is not voodoo or rocket science, the Dr made it easy for a reason.
Make it easy on yourself...lower the engine.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Senior Advisor
here are some pictures I did on removing the CIS from a 1981sc. With the motor in the car! took about 2 hours from start to finish. Not a big deal.
before ![]() after ![]() all the parts on the bench ![]() I didn't put it back in (went with carbs), but I could have.
08 Cayenne Turbo |
Putting it back is the hard part.....
Guys,
Appreciate it is an old thread. But I am about to pull my CIS (83 EURO). Two questions. 1. Do you remove the driver side intake runners leave the pax intake runners connected and pull it out? Or do you leave the drive side intake runners connectd as well? 2. Did it go in again without an engine drop (partial)? Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
