Tony
Maxhouse97's Avatar
Recaro PP seat install - help
Do these sliders look right? What is the vertical tab at the end for? Either it installs up or gets cut off, because it does not fit face down. My car is an 87 - did they give me the wrong ones? Others I have searched for on this board do not have the vertical component.
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 06-02-2012, 06:11 AM
cnielsen's Avatar
Are yours seats bottom mount or side mount? I though PP's were side mount like SPG's???
Those are earlier Recaro brackets, you need the later ones. I think I have a set. Post a pic of the bottom of your seats
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 06-02-2012, 06:44 AM
Tony
Maxhouse97's Avatar
They are side mounts PPs
Tony
22 GT4
04 E46 M3
Old 06-02-2012, 07:33 AM
cnielsen's Avatar
You need side mount brackets. Do you have those?
Old 06-02-2012, 07:34 AM
cnielsen's Avatar
'67 911S
'69 911S,
'70 911ST
'78 911SC backdate
Old 06-02-2012, 07:37 AM
Tony
Maxhouse97's Avatar
Yes I have those - just need to figure out how the sliders mount to the car.
Tony
22 GT4
04 E46 M3
Old 06-02-2012, 07:46 AM
cnielsen's Avatar
You should be able to unbolt the sliders off your old seats...unless they were full power versions. Can you photograph those?
Old 06-02-2012, 07:53 AM
You have tabbed sliders and you really should use the non-tabbed ones. That makes this process very easy to do.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-02-2012, 07:57 AM
I don't know how to mount a track seat, but as far as the sliders you need to get the type "without the tab" and the adjusting bar should mount to the inside of the two sliders, that's how to mount the aftermarket street type Recaro.
Old 06-02-2012, 08:03 AM
Tony
Maxhouse97's Avatar
Yeah I have the full power versions so I can't use my old ones. Thanks Steve I thought I had the wrong sliders - do you know the part number of the correct ones? Or are they just the "non-tabbed" universal Recaro sliders?
Tony
22 GT4
04 E46 M3
Old 06-02-2012, 08:05 AM
Tony
Maxhouse97's Avatar
Are the tabs meant for front mounted seats as opposed to my side mounted seats?
BTW the full power seats are heavy!!! Just carried them to the basement. OMG. I think I can visibly see my car increase it's ride height now that they are out. Amazing.
Tony
22 GT4
04 E46 M3
Old 06-02-2012, 09:47 AM
cnielsen's Avatar
The tabs are for some of the older recaros seats. You just need some standard flat sliders off an SC. You may need to enlarge a few holes as your hardware may be bigger. I've got a set if you want to trade for the ones you have.
Old 06-02-2012, 02:57 PM
Tony
Maxhouse97's Avatar
Let me see if I can return them first. If not I will get back to you. Thanks?
Tony
22 GT4
04 E46 M3
Old 06-03-2012, 04:05 AM
