Tony
Recaro PP seat install - help
Do these sliders look right? What is the vertical tab at the end for? Either it installs up or gets cut off, because it does not fit face down. My car is an 87 - did they give me the wrong ones? Others I have searched for on this board do not have the vertical component.
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
Are yours seats bottom mount or side mount? I though PP's were side mount like SPG's???
Those are earlier Recaro brackets, you need the later ones. I think I have a set. Post a pic of the bottom of your seats
'67 911S '69 911S, '70 911ST '73 911T Targa Signal Yellow '78 911SC backdate |
Tony
They are side mounts PPs
You need side mount brackets. Do you have those?
Tony
Yes I have those - just need to figure out how the sliders mount to the car.
You should be able to unbolt the sliders off your old seats...unless they were full power versions. Can you photograph those?
You have tabbed sliders and you really should use the non-tabbed ones. That makes this process very easy to do.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
I don't know how to mount a track seat, but as far as the sliders you need to get the type "without the tab" and the adjusting bar should mount to the inside of the two sliders, that's how to mount the aftermarket street type Recaro.
Tony
Yeah I have the full power versions so I can't use my old ones. Thanks Steve I thought I had the wrong sliders - do you know the part number of the correct ones? Or are they just the "non-tabbed" universal Recaro sliders?
Tony
Are the tabs meant for front mounted seats as opposed to my side mounted seats?
BTW the full power seats are heavy!!! Just carried them to the basement. OMG. I think I can visibly see my car increase it's ride height now that they are out. Amazing.
The tabs are for some of the older recaros seats. You just need some standard flat sliders off an SC. You may need to enlarge a few holes as your hardware may be bigger. I've got a set if you want to trade for the ones you have.
Tony
Let me see if I can return them first. If not I will get back to you. Thanks?
