86FlatSix
rear glass antenna
If I recall, this is an old cellphone antenna which has a base plate glued to the exterior rear glass, and a support plate glued to the interior glass.
PO left the base plate without the lead antenna. I have two choices: 1. Retain the retro look and source out the actual antenna screwed on the base. 2. Remove it but how do I take the glue out from the interior and exterior glass. Im afraid it might damage the defogger or there is a hole if I take that part out. With the permission from the owner, below is the one i'm looking for encircled in red. ![]() Your thoughts
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) Last edited by JQ911; 06-06-2012 at 09:55 PM.. |
In my 83 SC, I just pulled it off --- outside piece and inside piece. No glue residue, marks or damage to glass or defroster. I used a plastic interior panel removal tool. Slowly and gently.
86FlatSix
Could be the this one listed on ebay! Anybody has one? I just need the whip to screw on the base plate
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
I think the thread in the screw base are all the same. I have the exact same issue you have with my car.
What about trying this one?
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
86FlatSix
So now I just need to decide what option I will take. Do you think I shall buy the whip or just take it out?
I believe it cosmetically adds to the retro look. Your thoughts
It's not aero... I like clean lines so I'd get rid of it.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Since it will be non-functional...What is the point. I had one on my 72 911 but it was hooked to one of those old style box car phones. Also had a magnet CB antenna that blew off at 90 + racing an old 55 Chevy hotrod somewhere in Nebraska late one night. Shades of James Taylor in "Two Lane Blacktop"
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Most of these antennas were of the "capacitance" type...meaning there is a plate on the inside of the glass and one on the outside but NO hole through the glass.
Removing it should just be softening the glue (heat? .. MEK?) and prying off the plates. Bob
Bob Hutson |
I don't have a picture but on mine, I found a short 1 inch door lock knob that fit perfectly and looks like a short antenna stub (kind of on the same principal as the shark antenna on BMW's).
