cdill's Avatar
MAF Sensor Clip... HELP
Does anyone here have the little metal spring/clip that is on the 5 pin connector of the engine harness that clips into the Mass air flow sensor on a 3.6 that you may be willing to part with? I think that it is the same on late 80's through 993 models. or any ideas where I may find one.
I have checked every local source with no luck.
Thanks!!
Old 06-11-2012, 07:27 PM
Scott R's Avatar
Will this help?
6-Pole Female AMP Jr Power Timer Connectors
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-11-2012, 08:00 PM
cdill's Avatar
That looks like it may do the trick. I'll probably hold out for a couple days to see if someone may have just the clip laying around.
Old 06-12-2012, 05:48 AM
Here in Florida we have u-pull-it junkyards, look for BMW's of the same era as they used similar Motronic EFI. Cost is simply the price of admission and to me it's better than touring a museum.
Chuck.H
'89 TurboLookTarga, 336k miles
Old 06-12-2012, 05:49 AM
