NeedSpace's Avatar
Cleaning Fuel Tank - Acetone?
I have read a number of places a good way to get out the old varnish gas from the tank is to acetone and bolts and/or chains to agitate. I just want to double check, will the acetone damage the plastic swirl pot in the tank? Thanks in advance. I am hoping to do this tomorrow.
Old 06-08-2012, 06:15 PM
ROW '78 911 Targa
timmy2's Avatar
Maybe? That is why I suggested isopropanol (paint thinner alcohol) in the other thread.
Not as quick but also less harmful fumes to you and it won't hurt the plastics.
I've used it to clean my injectors, did a great job.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-08-2012, 07:48 PM
Porchcar guy's Avatar
Acetone
Acetone reacts differently to all forms of plastic. I am in the optical business and acetone is used to clean CR-39 plastic lenses without harm BUT plastic frames of acetate or Zyl plastic will denigrate almost immediately on contact. I would not use it in a tank with a swirl pot without knowing what form of plastic it (swirl pot) is. YMMV
15 year PCA member
1972 911 E Coupe - gone now
1987 Mazda RX-7 2+2 - still cooking
Swift DB-1 FF & Swift DB-3 F2000 -not forgotten
1979 911SC 3.0 & 2000 Camaro
Old 06-08-2012, 09:37 PM
porwolf's Avatar
Acetone is very agressive. I would not trust it not to attack the swirl pot. Denatured alcohol usually does not attack plastics. I suggest to just try to mechanically clean out crude stuff with screws, or that kind of material. Take good care of the small area just around the outlet at the bottom of the tank where the mesh filter srews in. That is the important area. You can access it with the mesh filter removed with l-shaped coat hange wire and rags. Carburator cleaner as cleaning agent works good there too. Coarse stuff in the upper part of the tank will be kept back by the mesh filter.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 06-09-2012, 01:16 AM
Chain fence eating turbo
We store acetone in plastic bottles at work. Not sure what composition of plastics they are though.
Old 06-09-2012, 09:11 AM
76 911S Targa
I would use a hot detergent solution to remove organic deposits. Follow this with hot water to remove the detergent and then finally alcohol to remove the water. None of these things should harm the plastic parts inside the tank. Another alternative is to use Matt Gineo's method of cutting a hole in the tank and replacing the cutout with a marine access port.
Cleaning a Fuel Tank without damaging Plastic Swirl Pot
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 06-09-2012, 09:33 AM
Scott R's Avatar
Why go to this level of effort? It's $40 to have most tanks professionally steamed cleaned, turnaround time at my local guy is about 24 hours. Save yourself the headache and chemicals.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-09-2012, 10:25 AM
Banned
Most likely low-density polyethylene.
Our squeeze bottles in the lab are made of it...
Old 06-09-2012, 11:23 AM
Good to know
Old 06-09-2012, 12:35 PM
NeedSpace's Avatar
Thanks for your recommendations. I was asking about acetone because I already had a gallon available, I didn't have an isopropanol. I DID have some Purple Power. I decided, let's try this and see how it goes, then if that didn't work, I would go out and purchase some of the paint thinner. It worked like a charm. Thanks for your help!
Old 06-09-2012, 06:09 PM
NeedSpace's Avatar
Oh, scott, btw, in northern nj outside of manhattan, to get the tank steamed is about $100 or more. Labor costs are out of control here.
Old 06-09-2012, 06:57 PM
matt gineo's Avatar
If your swirl pot is anything like my swirl pot your engine will never run more than a minute. After i cut a hole in the top of my tank i reached in and removed the cover to the swirl pot and found the inside of the pot was full of all kinds of Crud. steam cleaning would never get the inside of the pot clean. check out my thread to see how i cleaned it. shes running like a top now! Clean fuel is one of the most important factors of a great running engine.
Good luck
Matt
1976 911 Targa 2.7 CIS
Sienna Metallic /Diamond Sahara # 436-9-3 - Red Interior
1963 356 SC- crashed
1962 356 C- sold
1965- 912- sold- fun but too slow
Old 06-09-2012, 07:14 PM
ROW '78 911 Targa
timmy2's Avatar
This one?
Dennis
Old 06-09-2012, 10:37 PM
matt gineo's Avatar
Yes thats the thread
1962 356 C- sold
Old 06-10-2012, 05:35 AM
Try Marine Clean which is sold by Por-15. I used it to clean out a motorcycle tank full of gunk. Evapo Rust is great for removing rust.
Craig
'69 911T
Old 06-10-2012, 08:06 PM
Old 06-10-2012, 08:28 PM
matt gineo's Avatar
+ I wouldn't use a chain, gravel, nuts bolts etc. or anything else that would damage the swirl pot.
1962 356 C- sold
Old 06-11-2012, 02:09 PM
A common trick I used in the past was 20 liters of diet coke and a towing chain. The diet coke is so acidic that in a week it converts the rust on the inside of a tank so some tough black neutral layer. Just shake it like crazy once a day for a week, then drain the crap out.
Old 06-11-2012, 02:45 PM
NeedSpace's Avatar
Coke, no kidding? Did you learn that on mythbusters? Who would have thought!
Old 06-11-2012, 06:24 PM
Old 06-11-2012, 07:26 PM
