Cibie and Front Valance Mount Questions
I am replacing the valance with foglamps on my 1980 SC with a stock valance w/o foglamp openings. At the same time I am replacing the headlamps with Euro H4's and mounting repro Cibie's on the hood. I have a couple fundamental questions for my install:
- Will I use the stock foglamp wiring for the Cibie install?
- How do I remove the stock Bosch foglamps? Do they simply unplug at the light or at the other end of the wiring?
- Anything else I should be aware of or R/R while I have the front valance removed?
Thanks, as always, for the advice!
Marvin
1986 944 Racecar
2000 Boxster ClubSport
Old 06-12-2012, 04:52 PM
nineball's Avatar
those are stock fogs, but not SC fogs. they are from a carrera. they attach inside the housing with push on clips. remove the 2 screws on either side of the lense, remove the cover, remove the lense. look inside the reflector plate and you will see a little hole/nub on one of the log sides. pull the opposite side of the reflector out and then it will all fall out (may take a little wiggling here). the connections will be obvious at that point.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 06-12-2012, 05:15 PM
Thanks, that makes sense because they were mounted in a RUF style valance. Do I use the wiring for the Cibie install?
1986 944 Racecar
Old 06-12-2012, 05:17 PM
nineball's Avatar
i don't see why you couldn't. they would work just like your fogs did (same switch). it's just a + and a - line after all
Old 06-12-2012, 05:34 PM
You can also unplug them inside the deck lid.. Don't know the wattage difference, but you may want to install relays..
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-12-2012, 08:44 PM
Formerly known as Syzygy
Canada Kev's Avatar
Are the fogs not already on relays from the factory?
Kevin
Old 06-13-2012, 06:24 PM
Red face
I just checked the wiring diagram.. Indeed they are, my bad..
84 Mustang Turbo GT
Old 06-13-2012, 08:46 PM
That is good news! I have disconnected the foglamps at the light and routed the wiring back up into the front trunk area. It seems that leaving this wiring in place has taken care of what could have been a real headache..... wiring for the Cibie's. Thanks for the advice.
Marvin
1986 944 Racecar
Old 06-14-2012, 08:04 AM
