Go for it...more low end also, as well as mid and high
Me...SmileWavy
Anthony. |
Go for it!! I have the SW chip for 93 octane fuel with the stainless M&K cat bypass, and factory modified airbox (lid opened up) with the paper filter. Great low, mid and top end pull, great sound and fantastic fuel mileage to boot. Steve also offers the best customer service I have ever had the pleasure to deal with. You wont be disappointed.SmileWavy
I put one in my dad's 88, which I drive frequently.
Steve provides great support. After opening up the ECU on the car I found it had a replacement box with the wrong factory chip for an 88. I called Steve and he walked me through how to determine what was in the car. He then offered to exchange the chip for the correct one at no charge. The chip deffinately improves drivability around town. I don't think it makes the car much faster, just more satisfing to drive around town. I think there is a little bit of hype surrounding these chips, so I was expecting a little more of an increase in power than I felt. Either way, it was money well spent. I would describe the 88 as sluggish at low RPMs before the chip. With the chip, I would now describe it as peppy. I added an M&K cat bypass and it increased the overall power just a tad more. The 88 still can't keep up with my 81 though :D |
The reason i spoke to Steve W and decided to give his chips a go, i wasnt expecting any aditional power just better driveability, i was a mechanic for many years and built Tarmac race cars etc, so i know there isnt anything magic going on just plain old development time and experience in knowing what parameters to change within the MAP to gain the desired results. Anthony,TD... |
Yep Have a Wong chip, and cat bypass.
Really like the combo. Never switched the chip for emissions CAT yes. Never failed either. |
Beside that, he's one hell of a nice guy. |
I think the SW chip made a difference...better idle on start-up and more power. I also did all of the recommended maintenance including O2 sensor, spark plugs/wires, valve adj, distributor cap/rotor, clean distributor, MAF adjustment, throttle check and full throttle check. I also dropped about 200 lbs in unwanted weight which always helps.
I think the best choice is to get a custom chip that you can measure and get the air/fuel ratio checked. This way you can tell if you are getting improvements. |
Regarding his over-the-counter chips, Steve has enough data on these motors, over a long enough period of time, to create statistically significant conclusions to optimization of air and fuel ratios. His OTC chip is not like putting a supercharger on your car, and you might only feel an incremental improvement, but the guys running the POC PDS program see the difference in lap times for sure. |
| All times are GMT -8. The time now is 12:17 AM. |
