Ubi bene ibi patria
Need help in identifying this part
Hi Guys
I managed to not photograph or sketch up what & where this piece belongs during my dis-assembly process. ![]() To the best of my recollection, it is from the front trunk/gas tank area. It is 19" (48 mm) long (avg. length) & 5 1/2" (14 mm) wide x 1/4" (6 mm) thk. It is also a 5 ply type of wood. So what is it & where does it go? - after minor repairs of course Thanks & Cheers JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
Not 100% sure but I think there is a sleeve in the front trunk carpet that this goes into to make it stiff and fit better. I will check later when I go to the garage.
motoman is correct.
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
Ubi bene ibi patria
Thank you Gentlemen
Cheers JB
cycling has-been
it's angle cut at one end to fit in the integral sleeve. the angle goes towards the leading edge of the mat......see the seams inside of the red border?
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
