Help Me Evaluate Wheel Options
I am ditching my current 7.5 front 9 back 17" wheels and moving closer to spec. When I drove aggressively (particularly with much of an extra load), the left rear tire was rubbing the flare. Plus, I'd like to make the ride a little softer.
From my reading around I believe Porsche originally shipped the 79 SC with either: 185/70-15 and 215/60-15 OR 205/55-16 and 225/50-16 Would 7+8x16's fit this spec? I only need about 1/2 inch more and the tire should miss the flare. I'm also looking at getting some new wheels, but a good trade sounds more economical. From what I can tell, Fuchs are too expensive to be an option. I'm not particular as long as I get some good wheels and don't have the flare issue any more - this is my DD.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
I sold my polished 6-7x16 Fuchs and bought 7-8 x16 aftermarket black centers - same offsets. I have Kumho ASX in the 205 -225 setup. No problem on the rear but front left did rub until I rolled the lip from 10-2position. As you know, all of these cars set up a bit different so YMMV. Also set the alignment-corner weights and ride ht. at that time. Love the look now and love the Kumhos...BTW
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
We would need to know the offsets of your 17's. But 911 fitment 16 x 7's&8's Fuchs will fit in the fenders well and work with the 16" tires you have listed. I'm assuming you mean Fuchs when you are talking about wheels.
This picture should help you with OEM wheel sizes.
Thanks for the great diagram. I'm actually looking at some MSW's. This is a DD so I don't need track or show wheels, just something that fits properly and looks right.
Going back to '76, Carrera 3.0 w/ the same body as an SC was offered oe w/ 7ET23.3 & 8 ET10.6 x15 w/ 205/50 & 225/50 tires Those are 2 solid fitments for you car I've also used 7ET23.3 & 8ET10.6 x16 w/ 205/55 & 225/50 tires, the front gets a bit tight at the lips w/ these wheels and lastly instead of 8ET10.6 you can use 9ET15 w/ 245/45 x16 tires I'm glad you enjoy the diagram, I originated it
86FlatSix
What 17s wheel set do you have now? Should you plan to sell it let me know. Thanks
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Personally I'd try to stick with the Fuchs. 7 & 8 would be nice but expensive (the 8's). 6 & 7's are FS on the forum quite often for reasonable money (6-800.00 for a set). Actually a set on here today which looked real nice but may be sold already. Have no clue what aftermarket wheels go for but if they're in that range then I'd stick with Fuchs.
If you go with 6 & 7's you'll be running 205/55/16 front & 225/50/16 rear. Decent selection of tires in those sizes. Will have zero clearance problems with those even a little below Euro height. I'm a big fan of Yokohama S-Drives. Good looking tire & excellent performance for the street. Right around 400.00 for a set from Tire Rack. You may find however that these changes won't soften the ride much. If you're getting a hard jarring over expansion joints, etc. it's probably due to shocks or (more likely) worn out suspension bushings. When I bought my current SC it had the same wheels you've got now. Luckily I also got the original Fuchs in the deal. Bought the Yoko's & made the switch right away but have to say I noticed little if any change in the ride quality. The Fuchs weren't in great shape cosmetically so I stripped them & refinished them totally with Wurth black trim paint. Came out excellent & am really happy with the look. I don't have a camera but I'll see if I can get you a pic in the next couple days. My car's the same Wine Red Metallic as yours. Good Luck, Steve (978)764-7620 Last edited by sparkle84; 06-25-2012 at 04:57 PM.. |
My SC came with 7 and 8 x 15. Not too many tire choices in 15 it seems.. Only a few more in 16". Seems 17" is where its at when it comes to cheap and plentiful tire selections.
So.. Various factory sizes that will fit: 6and 7 x 15 (or 7x15 all around) 7and 8 x 15 6 and 7 x 16 (or 7x16 all around) 7 and 8 x 16 7 and 9 x 16 * I used to call my 15"s my "buicks" since I ran 205/60-15 front and 215-60-15 rear. These gave the car a very soft ride and were actually pretty "comfy" on the broken up streets in the NYC area.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
fwiw i went from 6&7-16 fuchs to a set of 7&8-16 msw ceres wheels and my front left wheel rubbed while at mid-ohio even after rolling the fender lip. for normal everyday driving i have never had a problem with it though.
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
"Normal" driving wasn't a problem for me, but I kept having a tendency to load 3 friends in and have a little fun... that's when the trouble started. Thanks for all the input from everyone, I'm definitely getting a good idea of what should work. I'm currently pursuing some 7&8 -16 MSWs. With the current 9" in the back barely rubbing, I think the 8" should be great.
Trim a little off the wheel lip with a grinder and call it a day.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Not a bad idea. I'll look around for matching Cups at 8". I'm hesitant to take a grinder to the body - what if I make it look horrible and ruin the paint too?
Grind the rear isn't going to make a difference. 1) There isn't much of a lip to begin with, and 2) when you rub in the rear it's usually about an inch above the fender lip. Get it fixed quickly because you can burn your paint where the tire is rubbing.
I've been looking around everywhere, and it looks like good Fuchs can be found for 800-900. There doesn't seem to be much interest or supply for other wheel types, I've only a few leads that aren't Fuchs in that price range.
I'm pining away to drive the car, but at least I have something else to get to work until she's back online. Tire Rack, in Indiana, offered to do a full laser measurement and find me wheels that would fit (at no cost beyond what wheels i buy) if I can get the car to Indiana. They won't sell me anything without being sure it fits, and they haven't had any SCs come by their headquarters for measurements. Sadly, with one rear tire significantly rubbed down, I don't want to risk the drive. It won't rub any further (just don't put 4 people in it) but a blowout would be disastrous. Any Milwaukee area Pelicans want to lend me some rear wheels for a weekend so I can get to Tire Rack? Realistically, I think I'll find a trade or buy some via our online Pelicans.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. Last edited by OsoMoore; 06-27-2012 at 02:04 PM.. |
Would running 16x7's all around, instead of the rear wider than the front, have noticeable impact on a daily-driver?
It is my humble opinion that "Stock is Trick". That being said, the only choice to be made here is what size Fuchs do you want to run.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Bill I am using 7X15 F and 8X15 R with 205, 225 but I wanted to switch to 8X15 and 9X15. Will the fronts have clearance problems on a euro height 86 Carrera? I was going to try the rears on the front but it is hard to tell unless you drive hard.
