starter problem
Hi guys. Today I installed a new starter on the rebuilt 3.2 engine. The starter turns
but doesn,t reaches the ring. I measured the distance from the starter mounting surface to the ring and got 51mm. The ring is too far. Later I tried another original Bosch starter and got the same result. The first starter was light weight HT starter.The sound is like I don,t have a ring at all. Can somebody tell me why the ring is too far.
Old 06-30-2012, 03:07 PM
Racer
winders's Avatar
Did you put a ring gear on the pressure plate? Are you sure you are not looking at the timing teeth on the flywheel?
Scott
Old 06-30-2012, 03:21 PM
thank you Scott. Take a look at this short video. What do you see?[IMG]338[/IMG]
Old 06-30-2012, 03:43 PM
sorry, can,t find how to insert video.
Old 06-30-2012, 03:44 PM
Racer
winders's Avatar
Just take a picture.....
If the "gears" you see are 51mm (2 inches) in from the starter pinion gear, you are not looking at the ring gear....
Scott
Old 06-30-2012, 03:58 PM
Senior Advisor
James Brown's Avatar
rut row, me thinks you should see 2 sets of gears when you look in there, one is the sensor gear, the other is the starter gear.
08 Cayenne Turbo
Old 06-30-2012, 04:09 PM
I will
51mm is from the starters body mounting surface which sticks to the transmision to the ring[?]
Monty
Old 06-30-2012, 04:10 PM
Thanks guys. I feel like a champion of the stuppid questions.
Old 06-30-2012, 04:12 PM
Senior Advisor
ok, it should have one of these flywheels with the tone ring on it
then you have the pressure plate
with the starter ring gear bolted to it
that's what you have, right?
clutch disk omitted but it's in there, right?
08 Cayenne Turbo
Old 07-01-2012, 10:55 PM
no ring gear in my engine. Funny and stuppid storry. Thank you James.
Old 07-02-2012, 12:40 PM
Senior Advisor
man, you are going to be so good at dropping engines. think of the good side
08 Cayenne Turbo
Old 07-02-2012, 01:26 PM
Friend of Warren
You weren't the first to have made this mistake. Neither was I.
Kurt V
Old 07-02-2012, 01:54 PM
It,s good to know I,m not alone Who want,s to start a new thread-- most stuppid thing I did to my car?
Old 07-03-2012, 03:44 AM
mcaterino's Avatar
+1 on looking on the bright side.
BTW - there are a good number of threads on peoples' mistakes already. Search 'oops', 'embarassing', 'stupidity', 'blunder', and 'bonehead', just to find a few. They're all instructive reading!
Cheers,
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 07-03-2012, 07:00 AM
Hi
Targa Me's Avatar
LOL, I forgot to put on the ring gear once...boy, talk about making you feel dumb.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 07-03-2012, 07:19 AM
