-   -   Why windshield trim should be a regular maintenance item. (http://forums.pelicanparts.com/porsche-911-technical-forum/686953-why-windshield-trim-should-regular-maintenance-item.html)
ghamilton 02-19-2018 12:08 PM
A quote from my shop who do a lot of high end cars and customs windows:
"We use a Sika product called Mach-60 to seal rubber to body and rubber to glass. these are used mainly to prevent water from entering car."
https://can.sika.com/en/solutions-and-products/new-products/sikatack-mach60-autoglass-replacement-adhesive.html
NFI
KTL 02-19-2018 12:22 PM
That Sika Mach-60 is basically rubber urethane adhesive. It's for the later style windshields (993-up) that do not use a preformed seal and are glued into the body, then decorative trim applied afterword. The stuff turns to pure rubber when cured. One of 3M's version like the Mach-6- stuff is called Windo-Weld.
We want to fill the void around the seal with a bedding and glazing compound. It's a non-hardening tacky goop that fills the void. The urethane stuff is not a problem, it's just unnecessary because it makes for extra work the next time the glass is removed and replaced
RDM 04-15-2018 11:35 AM
Of course my German neighbor had something to say: "You must do it like the Porsche factory says."
Which is?
http://forums.pelicanparts.com/uploa...1523820651.jpg
So the argument would be that new materials offer a better solution to what they had then.
In the mean time, I am back to cleaning old window cement from the windshield and Targa window channel....
Maybe with benzine!
wayner 04-16-2018 02:54 PM
The current argument that people use is an assertion that the factory didn’t use ANY
I’ve asserted that while you can debate the modern glues, you should use a glazing compound at least
You document FINALLY supports that
Thank you thank you thank you
wayner 04-16-2018 02:57 PM
3m Auto Bedding and glazing compound
