Zombie
Wur '80 sc
The car has rough idle, both cold and hot, with no power on accelleration with backfire/popping if too much pedal is used. The wur is only 10 ohms.
Any thoughts? Thanks.
Old 07-06-2012, 11:16 AM
Josh D's Avatar
Major vacuum leak or crossed plug wires is my thought
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 07-06-2012, 11:30 AM
Wur (0-438-140-072)
PM sent.
Tony
Old 07-06-2012, 12:46 PM
Zombie
Was running fine so it couldn't be plug wires. I had considered a vacuum leak but if it was would the rpm still drop when removing the oil filler cap?
Thanks for the responses.
Old 07-06-2012, 12:57 PM
Fuel pressures......
David,
Have you checked your fuel pressures (control and system)? If the RPM drops 200 or more after you removed the oil cap, it's an indication that you didn't have a significant air/vacuum leak to effect fuel mixture. Have you checked your ignition timing and spark? Keep us posted.
Tony
Old 07-06-2012, 01:19 PM
ROW '78 911 Targa
timmy2's Avatar
How old is your fuel filter?
Simple Stuff first...
Old 07-06-2012, 02:39 PM
Zombie
The fuel filter is about 2 years old but might have only had 2 or 3 tanks of gas through it. I have an extra so I'll give it a try.
Old 07-07-2012, 08:52 AM
I just went through this and found the leaks by hooking up a clean shop vac in reverse to the intake and taped it up. Then I sprayed soapy water on everything! You will be blown away at how many leaks you may have!!
Old 07-07-2012, 12:06 PM
