It took only 49 years!
mclmk8d's Avatar
Porsche Crest Squeaking like a cheap motel bed! Front sway bar suggestions
My car came with Weltmeister sway bars front and rear. While I have no complaints about the rear, the front squeaks like a cheap motel bed being vigorously used...
Anyway, I'm pretty tired of the noise, and was looking to get some recommendations to replace it...it is a through the body bar. As always, thanks in advance.
Serge: In the heart of Philly!
Daisy - 1972 911T 2.7L Light Yellow
Veronica - 1987 911 Carrera Coupe Indischrot, M&K GT3 muffler and Euro Pre-Muffler, SW Chip SOLD
Lil Blue - 2002 Subaru WRX Wagon (my dd/HPDE car) SOLD
Old 07-09-2012, 07:18 PM
Max Sluiter
Flieger's Avatar
Tarett. Top notch product.
Old 07-09-2012, 07:20 PM
moneymanager's Avatar
+1
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 07-09-2012, 08:59 PM
Evil Genius
Rusty Heap's Avatar
don't have a clue on your sway bar noise.......
........ but THANK YOU for the flash back to my most surpreme performance of all time at the Lighthouse Motel and a raw and uncensored un-caring for the people next door college era mattress squeeking and headboard banging moment.
before one can become old and wise, we must all be young and foolish...heck yah
Life is a big ocean to swim in.
Wag more, bark less.
Old 07-10-2012, 07:02 AM
mclmk8d's Avatar
Tarett Vs. Elephant Racing?
Any other suggestions? What is the difference between Tarett's front swaybar and Elephant Racing's? The photos on the respective websites are exactly the same. Does ER make the sways for Tarett?
Old 07-11-2012, 06:31 AM
you sure it's your sway bar that's causing the squeaking? My squeak issue stemmed from my right front torsen bar rubbing against the inside of its tube.
Old 07-11-2012, 06:46 AM
Couldn't you just replace the bushings with something less aggressive? I know some of the firmer ones will squeak like you describe.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 07-11-2012, 06:52 AM
Sounds sort of drastic to replace the sway bar with another. The bar itself has no moving parts.
It's probably the bar-to-body urethane bushings that are making noise, but to help isolate and pinpoint the source, disconnect both drop links, inspect the friction joints of each drop link (rubber bushings, rod ends, etc.), then test drive. If the noise persists, it's not the sway bar (maybe a suspension bushing).
Lubing the SB bushings usually helps. WM supplies a heavy lube for this purpose.
Sherwood
Old 07-11-2012, 08:26 AM
GaryR's Avatar
Send a message via ICQ to GaryR
The only bushings mine uses are thin plastic sleeves that I spray a little WD40 into during season and replace every couple years (on a race car). I assume you tried lubing them with no results? Could well be the TB bushings if thats the case. Easy way to be sure is simply disconnect the sway bar and try it...
Gary R.
Old 07-11-2012, 08:57 AM
mclmk8d's Avatar
I just spoke to a Pelican rep; he suggested taking a hacksaw blade and cuting a few very shallow grooves (a couple of strokes each) on the inside of the bushing and adding graphite or grease inside those so it's sort of self-lubricating. I'll try that when I return from NJ. If that doesnt work, I'll try disconnect the bars and see if the TBs are the culprits. I know that Wletmeister has a history of squeaking almost as much as Mickey Moue.
Old 07-11-2012, 10:19 AM
Been here a while
my sway bars have helm joints that squeak as described, need to find a heavy lube for them....I can duplicate the noise in my garage, disconnect the sway bar links and the noise goes away, remove the helm joint and duplicate the noise off the car....
looking for 1972 911t motor XR584, S/N 6121622
Old 07-11-2012, 10:23 AM
Max Sluiter
Flieger's Avatar
I do not know if the Elephant Racing anti-sway bars are a knock-off of the Tarett or if Tarett sells them to Elephant Racing which then rebrands them. But either way Tarett is the source.
Taretts use a bushing like the Rebel Racing bushings which is a dry lubricant polymer so changing the bar in this case will entail changing the bushings and should eliminate the squeaking while also being a really nice anti-sway bar.
Old 07-11-2012, 05:33 PM
