CIS pop off issue
My car was not run for a couple of weeks. When I tried to started it, I heard an unusual sound from the engine bay and the car would not start. I am no mechanic by any means but I lifted the lid out of curiosity and looked around and everything seemed fine. I then took off the air cleaner and found the pop-of had itself poped off from the pressure, I presume. I then put the pop-off mechanism back in place,(after I removed the ring of old epoxy) put the air cleaned back on and presto, she started right up! It is now re-epoxied and runs great.
Has this happened to anyone else and is my spring too strong? Also, should I check anything else?
Old 07-14-2012, 04:20 PM
Pretty common issue, I had the same thing, don't know if the epoxy just gets old or doesn't get a good bond to the airbox.
Best,
Rutager
Rutager West
Old 07-14-2012, 04:23 PM
Senior Member
Jdub's Avatar
Yup, heard of this before. Be sure you have no air leaks around the base of the pop off valve by laying in a decent amount of beading. Spring strength is not related to this issue - the epoxy gets old and brittle by heat cycling.
'78 Targa in Minerva Blue
Old 07-14-2012, 04:38 PM
born2cruze's Avatar
Sure has, as stated the epoxy gets old and brittle
1977 911S Sporto
Old 07-14-2012, 05:19 PM
Thanks for the replies. I did clean the old epoxy off, who knows how old it was.
Old 07-14-2012, 05:32 PM
grateful user
don gilbert's Avatar
I gave up on epoxy, it will eventually fail, leaving you possibly stranded. I have used black urathane on around 6 of them now, no failures yet. my own still holding after 5 yrs.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 07-14-2012, 07:22 PM
This happened to me about 3 weeks after I bought my car. Scared the crap out of me because I was still in the "if anything goes wrong with the car, my wallet is screwed" phase. Called my mechanic and he told me to check the back-fire (pop-off) valve. Voila! It had come out. Replaced it and the car started right up.
Old 07-14-2012, 08:14 PM
Happened to me too, years ago. Since then I've carried a rubber expansion plug of the appropriate size in the glove box, just in case. Of course, the valve never came out again (umbrella effect).
Howard
'76 911S
'53 Nash (!)
'01 Audi TT
'82 GPZ-550
Old 07-15-2012, 04:16 AM
