looking to do leakdown/comp test
hey all. i really want to try doing a leakdown/compression test on my 911. seems pretty easy!! i have a few questions. i know nothing about air compressors. what size air compressor do i need. any recomendations on what brand? also where can i find a good leakdown tester. thanks
Old 07-15-2012, 05:48 PM
Northern Motorhead
wildcat077's Avatar
Aircraft Spruce sells good leak down testers ... you want the one with a .040 orifice for use with a 5 inch or less diameter piston.
Any compressor which will provide 100 psi is good although some people use 80 psi to do the leak down test for whatever reason.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 07-15-2012, 05:58 PM
83 911 Production Cab #10
JJ 911SC's Avatar
The normal flat pancake type 3.5 Gallon (135 Psi, variable) is fine...
As low as $50 but P-C is a good one for $100 3.5 Gallon 135 PSI Pancake Compressor-PCFP02003 at The Home Depot
Who Will Live... Will See
Old 07-15-2012, 06:00 PM
ivangene's Avatar
DO NOT remove all the spark plugs at the same time for the compression test
it can be a very bad experience - just sayin'
one at a time
Ed M
86' Coupe
Old 07-16-2012, 05:40 AM
Northern Motorhead
wildcat077's Avatar
Benz,
You want something like this with a 14mm extended adaptor ... maybe do a little reading on the proper procedures as far as leakdowns and compression tests go,you're never too safe !
Cheers !
Phil
Cheers
Phil
Old 07-16-2012, 06:56 AM
Home of the Whopper
I made my own for a couple of bucks.
It only uses one gauge plus one at the compressor.
Similar to this:
Automotive Cylinder Leak Down Test - YouTube
What do you guys think of this method?
I get repeatable results, but are they ~accurate?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 07-16-2012, 08:36 AM
porsher
aston@ultrasw.c's Avatar
Summit racing sell a few. Here's the Longacre product.
Longacre Racing Products 73010 - Longacre Engine Leakdown Testers - Overview - SummitRacing.com
I have been pleased with other Longacre products.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
porsher
Does anyone have a leakdown test procedure?
I did a quick search but couldn't find anything.
79 928 Race Car
Old 07-16-2012, 08:52 AM
vash's Avatar
just did it this yesterday with a friend. a cool unit with a trigger activation would be cool. the one we used looks like a copy of that longacre one..same yellow knob.
poof! gone
Old 07-16-2012, 10:02 AM
thanks for all the responses. i was thinking i would need a big a$# air compressor!! wasnt looking to spend lots of money for an air compressor.
Old 07-16-2012, 04:42 PM
