Installing WEVO shifter tomorrow
Installing my new WEVO all black standard shifter tomorrow for my 915 tranny. Does anyone have any notes on their install that I should consider while doing the job or is following the instructions from WEVO pretty straightforward? Any advance tips would be greatly appreciated.
72 911 T Targa 3.2
01 Boxster S
Old 07-20-2012, 07:26 AM
Follow the instructions, very straight forward. Take the time to really clean up your old shifter.
Old 07-20-2012, 08:16 AM
Removing the allen set screw that holds the cup bushing elbow is required to change the shifter tube bushing. Its tight. You might find it easiest to get in there by modifying an Allen key by shortening the short leg of the "L".
Have some synthetic grease on hand for those bushings.
You'll love the shifter.
Ken
1986 930 2016 R1200RS
Old 07-20-2012, 08:47 AM
gtc gtc is offline
abides.
gtc's Avatar
The large jam nut is most easily loosened while the shifter is still installed in the car.
Graham
1984 Carrera Targa
Old 07-20-2012, 09:21 AM
Thanks, that is the one thing I noticed from scanning past threads. Tonight it will get a shot of pb blaster and then before I take it off will loosen the nut.
72 911 T Targa 3.2
01 Boxster S
Old 07-20-2012, 10:18 AM
2porscheguy's Avatar
+1!
Also, it's highly recommended to upgrade the coupler to the Wevo unit, while you're in there....greatly improves shifting effort and smoothness IMHO!
Old 07-20-2012, 11:21 AM
H-viken's Avatar
Watch out with the springs. They are tightly wound and you want to be careful releasing them.
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 07-20-2012, 11:41 AM
How did you release the springs? A vice, c clamp or just hold it down and carefully release?
72 911 T Targa 3.2
01 Boxster S
Old 07-20-2012, 11:47 AM
H-viken's Avatar
I believe I put it in a vise.
911E Coupe -70
Old 07-20-2012, 12:42 PM
I put on safety glasses, held the plate down with work gloves on and slowly loosened the nuts....no probs!
Old 07-20-2012, 01:01 PM
shifter
Another satisfied customer. Install went without any issues. I have had it all apart before so everything was clean and easy to get off. Shifter is amazing, maybe a little stiff right now but I am sure that will break in. Finds every gear very easily. Thanks WEVO and fellow Pelicans. Next up, need to get WOT on my throttle linkage.
72 911 T Targa 3.2
01 Boxster S
Old 07-21-2012, 01:55 PM
