Mystery spring after engine drop, can anyone ID?
I kept seeing this spring floating around while I was working on the motor, and figured I would see it in one of my reference photos and figure out where it goes, but I haven't yet...any ideas?
I'm planning on re-installing the motor tomorrow evening and would like to put it back where it goes. It's a pretty light-duty spring, not the one on the throttle arm or the clutch spring. Any help much appreciated, thanks.
Audi 88 911 coupe felsengrünmetallic/graugrün 86 911 coupe silbermetallic/weinrot - gone but not forgotten 99 Boxster - gone but still in the family |
throttle return?
what year car
Ed M 86' Coupe |
That looks like the "outer" throttle return spring.
Some older cars have 2 of different diameters. The larger one goes over the smaller.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Enthusiast
Throttle return on the bellcrank which bolts to the case.
Jonathon 1982 911 SC www.avrmotorsports.com |
This
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
^^^+1... the throttle return is much shorter with equal length "hooks".
Hmm, I'll double check, but I'm pretty sure the clutch spring is a heavier spring, and a replacement for it came with the uber clutch kit that I bought through Pelican...I don't think this spring came off the underside of my transmission, as I haven't cleaned it, and I don't think anything that clean came off the belly of this 915!
I'll double check all the same, though; car is an 86 BTW.
Audi 88 911 coupe felsengrünmetallic/graugrün 86 911 coupe silbermetallic/weinrot - gone but not forgotten 99 Boxster - gone but still in the family Last edited by audi; 07-30-2012 at 04:10 AM.. Reason: content |
There is suposed to be 2 return springs connected to the bottom of the injection going to the accelerator platform on the top of the engine. The return springs are longer on one side much like the picture.
Bruce |
Bingo, I do believe that's the one.
Thanks!
