DME upgrade
Hi did any of you guys try this upgrade?
Sometime in 1987, Porsche upgraded the software used in the U.S. 84-86 911 Carreras, from a 2K to a 4K program. The primary differences were refinements for an improved idle and additional part throttle performance and response. All 84-86 911s can upgrade to the later 4K program by a simple jumper move and readjustment of the base idle speed. If your 911 is an '84, '85, or '86 model, there is a 50% chance your computer may be a 2K DME, in which case you will need to unsolder and move a single jumper to update it to a 4K DME. After you make this mod you can still run your old chip without changing the jumper back.
Your computer is a 2K unit if it looks exactly like figure 1. If it does not look exactly like figure 1, you already have a 4K unit, and do not need to do anything further. Figure 3 shows examples of computers that are already 4K DMEs that do not need any modification.
Converting a 2K 84-86 DME to use the later 4K chip:
Just unsolder (or clip off) the jumper that connects "B702" and "B1" and solder it (or a new one) between "B703" and "B704"
Note: this conversion will do absolutely nothing for the ROW/European spec 911s and only applies to North American and Japanese cars that come with a oxygen sensor and catalytic converter from the factory.
911Chips.com - Motronic DME Update
Let me know if its worth trying
Old 07-19-2012, 07:38 AM
Chain fence eating turbo
Pffft.....4K?
They had 8K too. My '87 had an 8K conversion to the DME to run a custom turbo chip.
BTW, I took a 2K to 8K. They all can be modified from understanding.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-19-2012, 08:29 AM
and is it worth upgrading to 4 k then? cause it seems easy to do?
Old 07-21-2012, 12:54 AM
Diss Member
Quicksilver's Avatar
The actual program code for the 24 pin DME's program was stored in ROM on the processor itself. The ROM chip simply held the maps for the desired ignition and fuel delivery. Having to work with a fixed program kind of ties your hands.
Then the DME was updated to 28 pin in the later part of 87. What this did is allow the program to be changed. The original program is still there but one of the jumpers is simply telling the processor to go to the external ROM for its program.
That is why the chip is bigger: To hold the actual program and also hold the fuel and ignition maps. This allowed them to make any program changes that they wanted and apply what they had learned from all the cars they had shipped.
When I had my DME repaired a couple years ago the one big change I made was having it updated to 28 pin. I put in the 1267355358 chip which is the last chip the factory made for the 3.2. It is identical to the 1267355330 Club Sport chip except for the redline. (6550 vs 6850 if I remember correctly) Seeing that the 3.2 has an internal rev limiter built in (ie: sketchy stretch-to-torque rod bolts that go boom when you over rev) I think the 1267355358 is much more to my wallet's taste.
End result:
The 28 pin update allows you to have the factory's latest programming as opposed to just the latest map. This gives you smoother idle, response and more power. All good stuff.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Last edited by Quicksilver; 07-21-2012 at 09:00 AM.. Reason: That grammer stuff...
Old 07-21-2012, 08:43 AM
^^^ This! Moving from a 2K to a 4K chip doesn't mean squat for a typical owner...it's the "subtle map changes" that net the differences in performance between the versions. Takes me back a few years (fresh out of college) when DMEs appeared and I was developing microcode for IBM.... PROM(s) & EPROM(s)...good stuff
Old 07-21-2012, 09:17 AM
SpecE30 Racer
jplucas's Avatar
My car is hugely different with 4k conversion & SW chip. Better at every RPM point.
Jeremy Lucas
FastTechLimited.com FlatSixes.com
84 911, 95 993, 91 SpecE30, 01 325iT, 05 K-Elise
gone: 95 M3, 04 S2000, 87 535is, 01 986S, 90 944S2, 85 Euro M535, 996 4L
Old 07-21-2012, 09:32 AM
Go back and reread Quicksilver's post. I've had one of Steve's chips for years, but make no mistake, place Steve's "maps" on a 2K chip, and the results will be identical to the same "maps" on a 4K version (or 8K, or 64 GIG version ). The larger capacity simply facilitates "upgrades" and some allow for multiple versions of the "maps" (all good).
Old 07-21-2012, 10:09 AM
SpecE30 Racer
jplucas's Avatar
Steve sent me a 4k chip so I have no SW+2k to compare to, just stock+2k.
Jeremy Lucas
Old 07-21-2012, 06:41 PM
tell me more about this steve wong chip how do i install it where do i get it?
Cause ive read alot about it.. Now my trottle responds is so slow.. is it normal? And ive heard you can easly upgrade the US 3.2 to european model?
Old 07-22-2012, 02:20 AM
Originally Posted by luyckxglen View Post
tell me more about this steve wong chip how do i install it where do i get it....
"Chips suck, case closed" - an infamous quote by one of Steve's incognito marketing agents . It's all in the search archives...nearly a decades worth of information and "debate". The OP has a link in his first post...
Old 07-22-2012, 04:25 AM
i am the op But okay i think ive got the main info.. only price is a lil high for a chip? 375 $ not incl shipping..
Old 07-22-2012, 05:45 AM
Oops...I wasn't paying attention . I'm not one who will claim it's an earth shattering upgrade, but I've had mine for years and it's a nice improvement. BTW, we have 93 octane here (so the timing is "safely" tweaked a bit more over the '88 stock version). If you by chance have an '84-86 MY, then you will absolutely "gain" 10 more hp than I did (Porsche changed the maps in '87). Although the price has increased since my purchase, as I recall, Steve offers a "satisfaction/money back guarantee". The man knows his stuff and offers great advice & support imo. Good luck!
Old 07-22-2012, 06:15 AM
