white rabbit
Air box installation clips
Hi all.
I just bought a 1988 911 and was preparing to service the air cleaner element and noticed that the rear two clips attaching the air-box cover were not clipped in place properly and the back of the box had a 1/2 inch opening. After cleaning the K&N Filter and trying to re-assemble the cover I found that I could not reach the rear clips because of my big hands. (perhaps this is why I found them loose) Question, How do you reach and Close the two rear clamps to hold the lid tight? Also the lid had several 1 inch holes drilled in it apparently to increase air inlet. wouldn't this also allow more hot air into the inlet? Should I repair or replace the cover lid for the air box or just let it alone? Don |
Don, I have an '86 3.2L Carrera and you are correct, the two clips on the back of the air filter are very hard to close. I reach around the throttle body with my left arm to reach the clip on the top. For the bottom clip it works the best for me to use my left arm by standing kind of facing away from the car and squeeze my left arm in between the air filter box and the (I guess) oil tank. Pushing and shoving and ignoring the scratches on my skin I can manage to close the lower clip in the back with my finger tips.
I have seen air filter boxes with the holes drilled in. It suppose to provide easier airflow through the filter, but I don't know if it does. Mine does not have the extra holes. However, the filter housing does have to clamp the filter tight or you will get unfiltered air into the engine. I would be more concerned about driving in the rain with all the holes in the air filter box and the filter element getting wet. Good luck getting those clips on tight. Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
It's a MAJOR PITA!!! I have found that if I move the ac hoses I can just barely manage to get them closed but it's at an odd angle so it requires a LOT of finger strength to actually get it snapped shut. Sorry, no easy tricks to do this that I'm aware of...maybe someone has a better solution.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Smoove1010
Same here - I used my right arm, expect scratches, grunting, cursing. Skinny arms work best if you have access to one... I had to loosen the AC compressor adjustment bolts to move the compressor toward the driver's side to gain a little clearance. In addition, some repair to the ridge on the fixed portion of the airbox was needed to give the clamp something to clamp on to These old-fibrous-plastic pieces are getting old and brittle...
Go-Kart Mozart
Run a zip tie through the latch and leave it open in a two inch loop. Gives you some extra reach and leverage. Not my idea, but one gleaned from Pelican.
Alternate is to slice off the lid leaving only the square ring that is reinforced and holds the filter in. Much easier to reach the clips. I cut mine along the tape line in the photo. Flip the lid 180* and it's hard to tell it's been opened up without a close look. ![]()
My big tip. Get everything wiggled into place and the front clips clipped down. The get your arm wet with soapy water. I can cram my arm in far enough that way to pull the clip down. The top clip on the backside is easy. The bottom clip is a pain. Soapy water works for me.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
You're better off with a stock Porsche filter...the K&N doesn't buy you squat and actually allows more minute particles through. The holes are there only for "the sound effect", many do this, or do like I have and cut the whole thing off like the pic below shows. Quote:
^^^ this...except I'd rather see an orange (Porsche) filter
Air Filter Clips
I found the best way to fasten the back clips is to change the air filter when I change the oil filter, with the oil filter removed, I manage to get my right arm around past the AC compressor, its tight but it works.
the bottom clip is easier if you can reach up from underneath.
Get rid of that airbox and buy a cone filter. It may do nothing for performance, but it sure opens up the engine compartment for easier access.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
white rabbit
Thanks for all the excellent tips. However once I took a really good look at the back of the box I found that the attaching raised spots that the rear hooks grab onto have broken off, Bummer. That is one reason that I could not get them to catch. So, for the time being I used a adjustable Velcro strap from front to back, at least until I can get CCM911 to tell me where to get that cone filter he mentioned in his reply.
I will eventually get this car sorted out. Thanks again to all. Don |
Go-Kart Mozart
K&N supplied by the PO. It's orange now.
J Sent from my ADR6425LVW using Tapatalk 2
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
Go-Kart Mozart
![]() ..... but since reading that it allows some dust in over the filter have debated going back to the air box but cutting it open similiar to what Jar did.
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
Come on Jeff,
So much room can be had. And by the way, kudos on the clean engine.I don't know enough to argue one way or the other. Disclaimer - I run a cone so I can have easy access to engine components. I am not saying it makes the car faster. I am not saying it is more silent. Here is one choice: Pelican Parts - Product Information: PEL-INTK911 Fabspeed Airbox cover: Pelican Parts - Product Information: FAB-911-CUP32 Oh, I checked the competitor's price for a cone setup - $229 Wayne wins this one hands down.
Here is mine. I know you guys like pictures.
I like Jar's idea vs all that $$ for the Fabspeed. And thanks on the cudo's. did my fan and housing over the winter. Besides, how could I argue with a guy and a 900SS/SP. Here's mine. Not an SP but lots of hotrod built into it.
white rabbit
Once again thank you all for the input.
I am going with the cone for now and will put an wanted add in the classifieds. Don |
I personally wouldn't risk my motor with a filter that doesn't work as well as a Porsche filter, but that's just me....and this mod doesn't cost a cent
.![]() Before the airbox mod:
white rabbit
For KC911,
Very nice eng. area. Is the modification the top photo,assuming the bottom photo is the stock unit prior to mods, it looks like mine in the bottom photo, If so How did you make the piece that is holding in the filter itsself it appears to have a screen of some kind over the inlet side. My air box would not look like this even if I cut off the air horn side. Looks good. Don |
