hidden kill switch ideas for 84-89 cars
I had a look about and found info pertaining to cars that still run points and even 78-83 SC's, but I didn't find any reasonable info pertaining to the DME cars.
Looking to install a kill switch, will probably put it somewhere creative (such is in full view on the dash board), but I'm wondering what ground or power can I safely disable without screwing up any of the electronics? I'm assuming someone has done this exercise already. |
under the left front of the driver seat, in line with the DME relay ground wire. easy and accessible.
That's what I did. Very easy to install.
1984 Targa |
83 911 Production Cab #10
From a PO, the heat levers had to be raise a bit. If not dead on the road (starter would not turn)...
Wer bremst verliert
Now the car will not run unless the lighter is pushed in. You can leave the lighter in the "off" position or take it with you. Everything looks stock...
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Doesn't the stock alarm system have an ignition cutoff? The alarm horn had been disabled when I bought the car. When the alarm is turned on by the key switch in the left door the engine will turn but won't start. I think the key switch is pretty cool and relatively hidden too.
Cheers, Jt -84 911 targa |
Cheers all.
I did read that breaking that ground from the DME unit can cause harm if someone tries to start the car without connecting it back up. I take it this is not the case? |
I like the old type dimmer switches...the ones that were up high on the firewall operated by your left foot.
They had 3 terminals...center for power in...sides for high and low. If you put the wire from the key to the starter into the middle terminal...and the starter to one side and the horn to the other...the switch will activate the horn when the key is turned...or the starter if you click the switch. Scares the thieves nicely....even if they have "punched" your lock. You could also attach the lights to the horn side to attract attention. Personally...I prefer CZ gas...quick..permanent...NO REPEAT OFFENDERS. Bob
Bob Hutson |
no harm yet on any of the cars i did it on. mine included.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relay.
I removed the DME relay from the DME attachment point, left it loose on the harness under the seat, and pull it out when I park the car in "certain" locations.
And, I do not keep the spare relay in the glove box. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
1984 Targa Last edited by scottb; 08-31-2011 at 02:26 PM.. |
Post #4 in this thread kinda made me shy away from that though. Cheap immobilizer ideas (hidden switches etc)? Is it baloney? |
Platinum Member
I once looked at a 993 that had a business card tucked in a crack on the dash, microswitch hidden behind it. Pull the card, no start..... |
Once the car has started, the power path is completely different. cool Bell btw.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Once started, it does not affect the running of the car but if you stall the car you better remember that you put the lever down especially if the train is coming ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
I find it by accident. The previous PO did not know it was related. The PO before him was in Quebec, where you cannot get insurance if the car is not equip with some kind of immobilizer. I just bypass it just in case of the famous stalling on the train track...
If I'm in any doubt about which wire we are talking about I'll post a pic! |
the brown wire, #85.
I can see that would be OK in the summer, but I leave my heater levers up in the winter anyway. I guess you have to remember to shut them off in the winter.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
