Battery question (yet another one)
I know this must have been asked several times, Search revealed no answer.
What battery should I put into a '71 911T. I am bringing one out of storage and the battery in it is flat dead. It was a yellow top optima with the negative post cut off the top and moved to the side. Didn't look very safe to me. I do want ot go with a single battery and this car is littered with radio equipment, alarm, dvd player, lights bells and whistles! The smuggler box is filled with a/c stuff so it must fit in the left side battery box. If this question has been answered in a prior post, pleas point me toward it. Thanks in advance. Scott
2008 BOXSTER S LE 2008 CAYENNE GTS |
Almost Banned Once
I know I've spent stupid money on batteries... I won't suggest any particular one but get something sealed.
The high end ones are all much the same but according to some people here, Optima aren't what they used to be. I use Oddesys in both my cars and I'm happy with them. The main reason I went with them is because of their small size.
- Peter |
With a lot of electrical accessories I think you should go with the stock 2 battery setup. I doubt you would find a single battery with enough power small enough to fit in the factory box. I use 2 Westco Miata AGM batteries. They are slightly smaller than the originals, AGM so there is no venting or acid spill problems.
Ed 1973.5 T |
Thank you for the insight. I like the 2 miata batteries idea so I'll try that first.
I have 2 interstate batteries in my 70. 911 is in the part number. They fit perfectly. Work fine.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
I did a single Optima on its side as I got tired of the preventative maintenance cleanup related to the Interstate lead acid batteries. You can see my install here:
Harry, Thanks! That was the thread I was looking for.
I never thought about placing the battery on it side! It is spill proof after all.
Except for the acid fume issues, they are great batteries. Here is a link to the interstate battery web site: http://www.interstatebatteries.com/cs_eStore/Content.aspx?dsNav=Arpp~12,A~Part+Number,N~2147384 794-2147384771-4294493361-4294493360-2147384903,Nr~AND(P_unique_id%3a911%7cPorsche_911% 7c1973_Standard+Battery_All)
