Home Engine Detailing?
I'm waiting to put new wheels on my car (spacers in the mail), and I just replaced my oil cam line.
I'm pretty sure there is still some oil leaking slowly from somewhere else. I want to find the source of the oil leak, I want the engine to look nicer, and I want to have fun messing with the engine. It seems like cleaning and shining it up is a good idea! What is the best way to go about doing that? I'm not looking to put the car on display, and I need to do it at home in the garage without removing the engine. What are some good solvents/soaps to use? Should I go after it with a scrub pad?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
Some simple green, a bucket of warm water, an old rag and a toothbrush.
Seriously. Don't use a scrub pad just yet, as this may be too agressive on the painted surfaces. Take your time, and just do a little each session. Think of it as an ongoing process. I just did mine, and the results are good. I'll put some pictures up this weekend.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
AutoBahned
wood scrapers for big gunk
then use limonene (orange oil) & a water based detergent, alternating them - use small brushes last use brake cleaner if you're finicky |
My only addition to the good suggestions above is to avoid strong degreasers as they tend to oxidize the aluminum and make it look worse. Once you get the engine clean, a wipe down every time you wash the car will keep it clean - I usually wash the car and after rinsing everything off, I use the soapy wash rags to do a quick wipe down of the engine.
Simple Green sounds like really good stuff - I did some googling and most people recommended it. I have to figure out if anyone in my area sells it.
The Porsche Club has a great doc on Zone 8's web site ( Southern CA Zone ) that outlines a Concours level detailing plan...I have used this and have won 3 full concours in the C-4 category this year - have fun...http://zone8.pca.org/Articles/concours101.pdf
RETIRED
Simple green will eat thru anodizing.....IF you use it, don't let it sit long. 'Purple Stuff' is a 50/50 H20 mix available thru chain parts stores. Works well....eats rubber gloves and kills spray bottle mechanisms.
Gunk engine cleaner....pricey but works. Consider a pressure washer for underneath. Cover intakes and distributor. Blow out dizzy cap afterwards anyways....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
P21s works well for me, & as Joe Bob recommends protect electricals & intakes.
Good Luck. |
Now, if you don't mind the smell, Original Gunk is the Bomb! Use on the bottom only, or your engine will smell like a chemical factory for the next three years, LOL. I used Gunk to clean the engine compartment while the engine is out. But, as always, start with the least agressive stuff, and work your way up.
I use the Wheel Cleaners that are designed for NON clearcoated rims.
it will not "etch" the raw aluminum pieces, its safe on all painted surfaces (fenders and such...) and it cleans great ! |
AutoBahned
There is a recent thread on Krud Kutter - one person said it was way better than Simple Green, IIRC. BTW - if the engine is out of the car, then explore the threads on what to do while engine out - use those search terms. also read up oil leak threads - there are certain areas that are frequent violators Be sure to spray all the nice clean Al & Mg with an oil, wax or Tectyl (search button again) - to make it ugly again (but protected). |
Reiver
get a biodegradable de greaser like "Holy Cow" (ace hardware) not aggressive like purple/green but does a great job....works well enough without worrying about rubber and alloy reaction.
I'm having good luck with straight Pinesol lately. It doesn't each aluminum finishes like Simple Green and also seems not as expensive.
be here now
I let my wife clean the underside of our 356 before entering the Porsche Parade Concours.....we won our Class and Division!
Rob.... '66 911, '74 911, '85.5 944, '69 914-6, '65 356C, '01 986, '04 955S, '97 993 C2S, '55 356 OUTLAW, '98 993 Cab, '55 356 Speedster, '06 955S, '58 356A, '96 993 C4S, '87 BD 911, '95 993, '06 997S, '11 997.2S, '74 914 2.7, '15 981S |
RKT,
you win!
1984 3.2 Cab (now toy) 1975 911S (old toy) Mercedes E350 W4 (snow car) 2007 911 Turbo (water and air pumper) 2012 Panamera 4S (for the wife, I swear) |
Back to the original poster, I too have had great luck with Simple Green. Someone also mentioned brake cleaner which works well too but be sure to wear gloves or it will really dry your skin out.
Mark B '73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold) |
RETIRED
In all cases read the instructions, wear eye protection and clothing. Flip flops aren't a good idea. It is primarily recommended for mag and aluminum that have oil deposits. A wire or stiff vinyl brush should be used to agitate the baked on material.
If anyone has pics of their engine compartment before, during and after a spray down, that would be very helpful. If you have pics of the motor's essential parts all covered up prior to water spray, please post those too. Thanks!
The Dude abides...
WERKD, any wheel cleaner product names that you can share?
Steve '03 Carrera 4S |
