Another quarter window weather-stripping question
I am trying to install the weather-stripping on the rear quarter windows on my ’71 911E. I’ve searched the forum and see a lot of folks having difficulty installing it. I had a little difficulty at first but once I lubed it with a little silicon spray, I installed it with no problem. The only problem that I see is that the weather-stripping seems to come off to easy. So I’m wondering if I installed it incorrectly. The fit looks look but I think once I reinstall the window, closing it will push the gasket off. Is the silicone spray too slick, do I have a bad weather-strip or have I not installed it correctly? I have not seen anywhere that people used an adhesive.
Regards
Chris
Old 08-02-2012, 11:24 AM
Classic's Avatar
Chris, you will find the the silicon spray will dry out some. The seal I assume is rolling off with you hand? I had the same problem.
When you fit them you'll find that they get trapped by the frame at the front, so won't roll.
I fitted mine and closed them with the latch, for a week or so, before trying to open them again, without any problems.
Classic 1969 911T
Old 08-02-2012, 01:32 PM
Thanks for the feed back. Did you have to trim your weather-stripping at all? The a couple of areas that don't match up with the old weather-stripping. Also the new weather-stripping has ripples on portions of it. Don't know how to get them out. The first two images are the new weather-stripping and the third is the old.
Old 08-02-2012, 04:32 PM
Classic's Avatar
Chris, the seal is pretty generic, I found the same differences with the new trim, but you won't notice it once it's in.
Same with the ripples, once it's installed it should relax.
Tony
Classic 1969 911T
Old 08-03-2012, 02:05 AM
Thanks again Tony
Old 08-03-2012, 04:18 AM
