replacing ignition rotor problems !
I'm attempting to replace my dist cap and rotor. Cap came off fine. Rotor doesnt want to come off at all. Gave it a couple a knocks with rubber hammer, twisted from side-to-side (moves about 1/2").....nothing.
I lifted up the thin metal cover that's beneath the rotor and the shaft appears to be rusted where it meets the rotor. Any ideas how to get this thing off ? Can I spray WD-40 on the shaft ? help ! thanks Tim 1985 Targa |
WD-40 is not likely to help!
I suggest a large set of Channelock pliers to rock the rotor back and forth ... maybe to the point of cracking and fracturing the old rotor!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
thanks Warren. I used WD-40 and got underneath of it with a screwdriver (being careful not to bend the shaft !). The channel locks were next.
Kind of concerned about the shaft being rusty. I would think that the dist cap keep most of the water out . I'm hoping I've solved my problem.....the rotor looked to be original (w/ 70k miles on the car !). thanks again Tim |
Senior Member
The best way to remove a really stubborn rotor is to crack it like a nut. This is the factory method for some (non-Porsche) rotors that are on REALLY tight by design.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
