Brando
quattrorunner's Avatar
Left turn sinal problem
So I had my rear bumper off for an engine drop, and the engine and harness had gone through some drama for about two months before it was all put back together. When it was back together, I didn't have front left signal. Neither hazard nor indicator. The dash light shows very light dim lighting of both left and right when left signal is selected. Right signal is normal. Any ideas?
Old 08-05-2012, 05:29 PM
Brando
bumper
Turbo powa!
1977 911s. it's cool
Old 08-05-2012, 09:02 PM
ROW '78 911 Targa
timmy2's Avatar
Check your ground point for the rear and front signals. Also take a look at your wiring and fuses where the turn signal is fed from. Could be a failing or loose fuse or wire connection screw is loose.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-05-2012, 10:59 PM
