Has anyone ever?
Has anyone ever used a O ring when changing oil on the oil and sump instead of a crush ring
Thanks Ernie 81SC |
Why do you ask?
Why not use a crush washer and prevent any chance of a leak? You can reuse the old washer if desperate; just sand it smooth . I wouldn't use an O ring , personally.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
Senior Member
Ya know, the Porsche factory has prolly tried all sorts of options and decided that the crush washer is the best. Personally I think that I will trust them on this...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Chain fence eating turbo
I'd think the o-ring would deform too much to seal properly.
O-rings have to be "contained" to work. |
Fleabit peanut monkey
The torque spec it pretty high on that plug. It would turn any o-ring to mush. I agree with everyone else, just replace it. Heck I have re-used more than a few of them with no leaks. I usually replace them but I have been in the middle of a oil change and realized I did not have any more new ones.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Go-Kart Mozart
![]() At the torque value where the crush washer works I have no fear of the bolt vibrating loose. I would think that a rubber seal would work correctly in a lower torque range. Would the bolt have a greater probability of loosening? I don't know but why chance it? On this one put me firmly in the "if it ain't broke, don't fix it" camp. J |
Hot oil, fragile rubber threads & torque, gee what could go wrong?
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
7.0:1 > 11.3:1 > 7.0:1
Search this on google and look at the images: stat-o-seal earls
You would need to see if the shoulder on the drain plug is wide enough that it will seat on the aluminum part of the seal. Provides O-ring seal, but allows torque to tighten the fitting. |
If that is used for high torque situations, the outer washer is taking the clamping pressure, not the o-ring. Notice it's "contained" too. |
Order crush washers fifty at a time and never look back.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
I have always used them and have had my car for 15 years, the thought passed my mind when I was cleaning out the garage and found a box of about 100 rings. I agree with all the posts and have about 20.
----------------------------- Ernie 81 SC |
air+fuel+spark
Just use the crush washers as designed.
I suspect that an o-ring is designed for a radial seal and a crush washer is designed to be sandwiched and then deformed under load. They do make rubber flat washers for sealing in some instances though.
bryan 1969 911T , '04 S2000, '96 900SS, 4x4 urban assault vehicle R Gruppe #653 |
