 Full Monty: 3.6L swap Turbo flares front & rear 993 Mirrors 964 or IROC nose |
 Regarding original/unmodified cars, I got my '78 SC with 170k miles and it had a lot of needs. Not being content to leave things stock, I made small "improvements" and upgrades to every system of the car. Because it was done incrementally, it was tough to judge how far the car had come over six years. However, last year I scored a creampuff '83 SC for my dad that had 51k miles and lived in a climate controlled collection its entire life. I assumed based on condition that it would be an amazing driving experience.  Nope, it kinda sucked. compared to my hotrod '78, it was underwhelming as a sports car. Dad, having driven both cars, wanted to perform most of the "must have" mods outlined in this thread. So we've done a top end rebuild (because head studs) with William Knight's M1 cams, RSR flywheel, SSIs and a M&K muffler. Between the motor, Rennshifter and 7/9x16 Fuchs (the new German ones), it drives like a different car. Huge props to William - those cams rock! It still needs turbo tie rods, stiffer torsion and sway bars, but it's infinitely more exciting to drive already. |
 Well this is how I ended up starting Classic Retrofit!  After SSI's and some 964 cams, I was after more reliability and some comfort. A more reliable fusing system A tunable CDI box A lightweight A/C |
 I'll add some easy overlooked ones that are musts based on bang for buck and effort to install...  I would call them 'upgrades' vs mods... Upgrade to OEM Cabriolet or 'Sport' motor mounts. Don't have to go extreme Wevo or anything - German OEM/Porsche fine. Noticeable reduction in engine deflection (esp. on hot days) and slightly crisper throttle response. Cheap and easy. Delrin bushing or upgraded Shift coupler (and then properly adjusted shifter). Afternoon bolt-ins that don't break the bank, don't butcher an otherwise nice stock car and last forever... Scott |
 My SC has the 930-10 ROW engine with SSIs.  The engine had been stripped down and professionally balanced.  It is a very revy engine and very smooth. |
 Just read my signature, all of these work together to make an excellent preforming SC. http://forums.pelicanparts.com/uploa...1635428680.jpg |
 For not much $$$ an amazing visual improvement. of course, the pop off valve and Carrera tensioners are no=brainers. 7" x16 front and 8"x16 rear. (or 9" rear, same visual) --OR --- keep the stock 7" rear fuchs with with a bolt on spacer to bring it out. (??? 21mm??? ) |
 Ian |
 popoff valve - to protect the CIS airbox chain tensioner safety collars - to prevent serious damage if/when tensioners fail SSI heat exchangers - to improve exhaust/HP and maintain heating turbo tie rods - to make steering more responsive better brake pads - wide selection, so pick those that are appropriate for your intended usage After that take your time and figure what your goals really are. It can be expensive to backtrack a hasty decision. Remember, it was already a Porsche 911. |
| All times are GMT -8. The time now is 08:17 PM. |
