What's missing here?
So I just picked up a 75 911S and it has some issues.
One of which is the turn signals and flashers don't work. I started troubleshooting and found this: ![]() I see that the flasher is no longer present???!?!?! I am also missing two other items/relays I believe. One of which it looks like somebody has made a jumper for. Maybe this is factory and are used for accessories my car did not come with. So, who knows what should be in the other two sockets?
'12 Cayman R 77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera, '65 912, '06 Cayman S - Gone |
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
The one on the bottom right should be the flasher relay.
Not sure on the other ones.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
I thought the flasher relay was the square socket.
Here's the thing. You are correct, the flasher relay is a square relay but the socket still may be round (I honestly can't recall on my 75). The key will be to look closely at the round socket on the bottom and see if the holes in the socket are for pins or spade connectors as the flasher relay uses spade connectors.
What makes me suspect the square socket in your picture is that I don't remember the socket being attached to the bulkhead with a screw, as it is in your photo. I remember it to be pressed in like the other round, rubber sockets. However, the flasher relay is typically the closest one to the back of the fuel gauge, which would make it the square one in you picture. A closer investigation might help or, at least, a larger photo.
