cycling has-been
bkreigsr's Avatar
HELP - how do you remove these mounting studs?
I tried a double nut and a razor under the snubber.
I want to keep them intact so I can easily convert back to blown heat in the winter.
thanks
Bill K
Old 08-13-2012, 05:15 AM
R&r
Grab the lower metal flange with a channel lock type plier and it will come loose, working through the rubber will usually rip it in half.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 08-13-2012, 05:25 AM
cycling has-been
bkreigsr's Avatar
good morning
thanks Mike - I'll try that tonight.
Bill K
Old 08-13-2012, 05:35 AM
