Banned
915 hybrid build need help
915 hybrid build.
Here is the picture, the left hand is a half 915/67, the right hand is a 915/02. As you can see the 915/67 is only left a few parts, if I move 915/02 gear and cover into 915/67, not remove the ring gear and pinion shaft, did I still get 8:31 ratio? My tech man is doing it right now, is there any tip I should let him notice? The trans will put into my 73 911E with87 3.3 turbo or 89 3.2 engine. Hope hear from you guys. ![]() |
Grand Am/IMSA Data Guy
The 915/67 has a stronger input shaft so that should end up in the tranny. What is the goal? Track car? If so, the 915/67 has a taller 4th gear than US version and not as good for the track, but better for highway cruising. The fifth gear which is missing is supposed to be a ZD/T (0.76 ratio), better for cruising, not great for track. My trans is a 915/67 and I removed the ZD/T 5th gear and it is available if you want to make it correct.
Jerry Austin AIM Data Products Dealer 84 911 3.6 track car - Sold Morris Minor Van with S2000 running gear http://austinmotorsportsllc.com/ |
Banned
Hi Porsche84
Thanks for the tip, the trans will not go for track, street only. I think my tech may remove all the mission parts from the 915/02.. Should I correct the 5 gear? Or just use gear from 915/02? Thanks Last edited by vinyl_tien; 08-14-2012 at 04:15 AM.. |
Actually, the real early 915's had tall 4th and 5th gears. I'm not sure what was in the 915/02. I'm sure someone will offer the information. My data shows early 915's to have a 29/22 which is essentially the same ratio as what what the /67 had. So, you might be good with what you have. You'll know when you pull off the nose piece of the /02. Does the /67 still have the external oil cooler? That would be nice.
here's the gearing
![]() 915/67 should have a cooler hung off the left side ![]()
Banned
Thanks for the tip.
I got the trans without cooler line. But the pump device should be in there(have not check it yet), I think I will get a small cooler for it. |
915 euro tranny
Does the center case and the diff cover have the holes drilled for the cooler? These might have been swapped out as they are pretty valuable.
Thread Tools | |
Rate This Thread | |
