Front strut rubber
Not sure what its called, but where the front struts come through the inner wings and bolt on, there is a rubber 'something' around it, mine have totally perished... What do they do and can i get replacements ?
911 3.2 1989
Sixty percent of the time it works every time
89 911 carrera convertible
2004 Saab 9-3 convertible
Old 08-14-2012, 12:40 PM
If you mean the black caulk stuff that keeps water out, I cleaned all mine off when I went with the Elephant racing adjustable camber plates. I got some plumbers putty from Home Depot (not sure the UK equivalent) which I like because it doesn't harden and removes easily. Seems to work, we get some serious downpours here in Florida.
Chuck.H
'89 TurboLookTarga, 337k miles
Old 08-14-2012, 12:51 PM
Flat Six
Flat Six's Avatar
Your description is not very clear . . .
Maybe you mean this?
Pelican Parts - Product Information: ERMP-2290001
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 08-14-2012, 01:00 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Agreed the black substance used as a sealant for the strut tops is a pesky material to deal with. It's a real pain when you need to do an alignment and you must chip the chunks away.
A heat gun is very effective at softening the black crud to allow easier removal. Then clean up the residue with an adhesive remover that is safe on painted surfaces. I have had great results with 3M General Purpose Adhesive Remover. Caution, use protective gloves. The 3M solvent is nasty stuff on your skin.
I have had good results using a non-hardening material similar to what Chuck mentioned. A material commonly used for sealing windows in your home is called "rope caulk." It's a white material that is similar to modeling clay and you can press it into the voids around the strut top to keep water out of the front trunk area. It's a bit more tacky than plumber's putty and stays in place quite well.
Kevin L
'86 Carrera "Larry"
Old 08-14-2012, 01:01 PM
If it is the rubber camber plate bushings pelican #ERMP-2290001 as in post #3 they are from
elephant racing and are very nice. Just installed a set in my 70 and plan to do the same for the 88. Simple DIY project. Get rid of the old rubber.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-14-2012, 01:17 PM
Thanks all...to confirm its the black caulk stuff..so somekind of waterproofing.... Ill try chipping off and using 3m remover as reccomended
Old 08-14-2012, 01:21 PM
Any pictures of how it should look... Either standard or repaired with plumbers seal...mine have perished and chunks missing, so im not sure how its supposed to look
Old 08-14-2012, 01:25 PM
AutoBahned
RWebb's Avatar
dum-dum, aka 3M strip caulk - made for auto use
Old 08-14-2012, 01:39 PM
