carrerarsr65
f.i. question
79 3.0 sc injectors feel loose can move them with hand easily this cant be norml?
Old 08-14-2012, 08:28 AM
Fleabit peanut monkey
Bob Kontak's Avatar
They are held in by rubber o-rings. The rubber gets pretty hard and does not seal like they used to.
Grab an injector and pull it straight up and out (with fuel line attached). Feel the o-ring and I bet it's pretty stiff from age.
Old 08-14-2012, 09:06 AM
Josh D's Avatar
In my case, the injectors are tight in the sleeves, but the sleeves are loose when car is not running. I noticed that when the car is running, they don't move as easily due to vacuum. I figured this was normal or maybe I read it was normal?
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 08-14-2012, 01:54 PM
