Can I modify a 3.2 Carrera Cabriolet Engine mount to Solid type
I have a Carrera Cabriolet engine mount and I want to make it a solid mount
Can I modify this mount so that my engine mount is solid ? I was thinking of Drilling 4 holes and adding the bolts/nuts like the solid type and cutting all the shock type stuff off. Keep the bolts for the donut hole as well Green = original threads Yellow= new holes for Bolts/Nuts Red= Cut off http://i60.photobucket.com/albums/h3...g/235b7059.jpg These images were borrowed from an ebay auction http://i60.photobucket.com/albums/h3...g/4e3b81e8.jpg http://i60.photobucket.com/albums/h3...g/0bb1dcc2.jpg Any one done this before ? This is all for my current project http://forums.pelicanparts.com/porsche-911-technical-forum/693701-dropped-row-3-2-engine-rebuiling-trans-while-there.html#post6905925 engine mount will be mated with the Rebel Racing Engine mounts http://forums.pelicanparts.com/porsche-911-technical-forum/695370-rebel-racing-engine-mounts.html#post6913748 |
Why not trade (with some cash in it for you) for a standard engine mount? The cabriolet engine mount and associated items are much more rare.
Brian |
Why bother? The standard mounting bars are cheep, the same for almost 20 years and available from the recyclers like EASY.
I got all the tools laying around to do the job
But I don't have all the cash to buy another one... Shops want an arm and a leg + I need to do this by tomorrow 9/17or tonight It would take too long to get a piece... According to PET the Item i need is specific to Carrera not 74-83 |
(Black Flag: Nervous break down)
I did it anyways ! This mount feels pretty thick (more so than I remember a Coupe version) I put the mount on a vice, Drilled the holes where I wanted them It took 4 different drill bit sizes 4 10mm nuts 4 washers 4 locking washers 4 10mm nuts While I was at it, I removed the shock mount It came out pretty good http://i60.photobucket.com/albums/h3...C/6bf1f855.jpg This is what I started with the shock was literally Blown! it could completely move with just a hand touch. http://i60.photobucket.com/albums/h3...C/5cc6b46f.jpg http://i60.photobucket.com/albums/h3...C/0c3cfcea.jpg sorry about the pic This is the hardware and 3 of the 4 drill bits used http://i60.photobucket.com/albums/h3...C/dd09de06.jpg Holes drilled before going to the last bit http://i60.photobucket.com/albums/h3...C/c4c0dbcb.jpg Cutting off the shock mount http://i60.photobucket.com/albums/h3...C/d733896f.jpg Final Product ! Not too bad Eventually I will get the proper engine mount.. but for now this will do better than what I had.http://i60.photobucket.com/albums/h3...C/1c4a11f7.jpg http://i60.photobucket.com/albums/h3...C/77f3212b.jpg Mounted on the engine http://i60.photobucket.com/albums/h3...C/1fc0dee9.jpg I'm hope this makes a bigger difference |
I have always wondered what the shock on my engine mount is for and have now learned that my 3.2 engine donor must have been a Cabriolet. My car is a Coupe and, with the engine currently out, I would like to return to a solid engine mounting solution. It looks like I would need to swap out both the crossbar AND the large bracket that attaches directly to the engine - correct? If so, where could I source both pieces, please? Thanks!
I'll sell you the pictured one already modified for $100 shipped
the non modified one is actually worth alot ( I didn't realize it at the time) I'm swapping engines and got a new mount |
Thanks, but I think I'd like to source a factory Coupe crossbar and console.
Looks good! Keep in mind, per factory manual, when you install the engine, after the 4 engine mounts are tight, loosen your 4 bolts on the crossbar to let the engine 'settle' and not be tweaked by any angle you may have when you assembled the crossbar. Just loosen all 4 and then re-tighten them.
Chuck.H '89 TurboLookTarga, 369k miles |
Any Cab prior to 83 did not start their life as Cab, so if the conversion happened before 83, will have a solid engine support. Yes the Cab version is almost 5 time more expansive ($737 vice $158). |
What is gained by having a cab engine mount replaced with a coupe engine mount?
And what was the factory purpose for using a different mount for the cab?:confused: |
This thread discusses why the cabs use a different engine mount http://forums.pelicanparts.com/porsche-911-technical-forum/753459-cab-owners-replaced-your-engine-vibration-damper.html
As to why to switch to a solid mount, seems replacing it with a solid one on a non-cab would both reduce weight and complexity in the rear of the car (where you want to miminize weight, etc.) |
Thanks Darrin!;)
| All times are GMT -8. The time now is 05:53 AM. |
