911 + 129 = JOB
Hard to shift into Reverse and First
Lately, I have noticed that when I shift into first or reverse (usually when I am backing out of the garage or moving it into first ) that the gear shift feels like it does not want to go the rest of the way in (and its not in the gear I selected).
I will usually pull it back to neutral and then try again or pull it into another gear (2nd) and then it will go into 1st or reverse. Any ideas? 89 Carrera Coupe
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
Have you bled the clutch master & slave lately?? If not, maybe a change of fluid & a good bleeding are in order.
If not, there may be a bigger problem related to clutch and/or pressure plate. My 1 cent.
'94 CMC Firebird Trans Am '86 951 LS1 (C-2) Gone ![]() ![]() '77 911 3.2 (C-1) Gone but not forgotten. http://www.pelicanparts.com/MotorCity/marcesq1 http://www.youtube.com/user/958Fan#p/u |
911 + 129 = JOB
I have not bled the clutch and slave. Is this a DIY project?
Clutch is about 5 years old with maybe 20k miles on it. I hope its not a bigger problem!
