At 3000 RPM, Oil level drops from 8 Qt to 5Qt
Is it normal for my 70 911T w/o ext cooler to have a oil level of 8 quarts in the tank at idle to drop to 5quarts at only 3000 rpm? This is with the engine at operating temp and driving for 5-10 minutes at 3000rpm. Sometimes under the same conditions, it may only drop to 5.5 quarts and sometimes slightly under 5.
My fear is that my scavenger pump might be starting to fail. Thanks for any replies. |
At 3000 RPM you shouldn't be looking at the oil level guage - only the road, the tach and the oil pressure guage!
The oil >>>Level<<< guage is ONLY "accurate" when ALL of the following conditions are met: 1) The engine is fully warmed up 2) The car is at rest on a level surface 3) The car is idling at its appropriate idle speed (<1000 RPM) Your memo failed condition #3 so you shouldn't be paying attention to the oil level guage. PS: How much oil did you put in the car in the first place? If in fact your guage is accurately reading 8 liters of oil in the tank at idle, you might have too much oil in the system. (PS: Duh - Yes I was talking about the Oil Level Guage, not the Oil Pressure guage. Sorry for the confusion! - John)
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 05-26-2002 at 02:43 AM.. |
![]() Last edited by clevy70911T; 05-25-2002 at 12:03 PM.. |
Administrator
The reading of the interior gauge means very little. When the car isn't idling at a dead standstill on a level surface, it means even less.
It measures oil in the tank. Since it's a dry sump system, this level is supposed to drop down as the oil pump speeds up. A good habit to get into is to check the dipstick (again, with the engine idling, on a level surface) after a long enough drive so that the engine is at least at 180 degrees. The level should be between the high and low marks on the dipstick, not all the way up to the high mark. It's an odd system, especially if you're used to engines with oil pans.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Banned
my gauge does the same thing, i never really worried about it cuz it never goes below 5. also i am not sure if i can really trust the gauge anyways i usually just watch the oil pressure gauge, if that goes below 5 then i would prolly be a little scared
Kyle 71 911 |
