Senior Member
ohecht's Avatar
CV Joint Failure Carnage
Doing about 50 in 3rd gear when the inner driver CV joint let go and took out the throttle linkage, brake vacuum booster line, and CHT sensor cables. I haven't even jacked it up yet for a full inspection since I just got it home last night. Just stuck the camera under there this morning.
Not sure if the bolts sheared or backed out, but there were no advance warning sounds and I was not on the throttle that hard.
The piece of metal wrapped around the axle is the throttle linkage pivot, and I assume the mount for it was ripped from the transmission...does anyone have a part number on that rod that mounts to the tranny and holds the throttle pivot?
Olivier, in for some ugly assessment and repair...
Olivier Hecht
1982 911SC
Old 08-29-2005, 05:06 AM
Wow! Yours is the unlucky version -- mine was lucky. 60 mph, downhill on Chippenham turnpike at Midlothian so no power on, and a big rattle. All six bolts backed out, no collateral damage. Thorough inspection and bolted it back up and drove away. There was no warning at all -- no rattle, bump, nothing as the bolts backed out.
Oh, yea -- mine was the inner right side, so fewer things to "get wrapped around the axle" with.
Old 08-29-2005, 05:19 AM
pyro57's Avatar
This same thing happened to me on Friday (without the damage).
I was coming off of the freeway doing about 15mph. Three bolts gone, one broken and two bent. make sure you check the mounting point to the transaxle for cracks or damage.
Good luck, Dave
'78 911sc,Black on black, new suspension, engine rebuilt, tranny rebuilt, lowered corner balanced, aw inspiring.
1964 1/2 mustang con. 289, Red/black,
1998 M3,Dinan, Harmon Karden
1979 Jeep 304 V-8, injected
2 Yamaha YFZ450 quads
1999 black Lab.(dog)
Old 08-29-2005, 05:58 AM
Senior Member
Happened to me in a parking lot - Was just starting to pull away when I heard a very bad sounding thump - WHACK
Stopped the car and looked underneath. Two bolts sheared and the others had back out.
Tried fixing it in the parking lot (was a sears after all) but between the black top being scalding ass hot and the sheared bolts I had to get it towed home.
I think you got lucky on the damage front - I have seen some nasty bits of mangled metal after that happens
78 Euro 911sc Targa
03 Hayden
SCWDP
Old 08-29-2005, 07:03 AM
kcf7z's Avatar
UNfortunately - I have had this happen too. Throttle linkage and heat exchanger suffered but otherwise no significant damage - Scary as hell though when it happens and the throttle linkage goes accompanied but a thud.
Good luck to you.
Old 08-29-2005, 07:09 AM
kqw kqw is offline
Oliver...
Were the CV's recently R&R'd?
It looks like the bolts backed themselves out.....
The Fox
Carrera
Old 08-29-2005, 07:10 AM
Somatic Negative Optimist
Gunter's Avatar
Judging by the amount of grease around the area, the bolts backed out, allowing the grease to be thrown out long before a complete disconnect.
Hopefully no major damage.
A few people will be encouraged to inspect their CV bolts after seeing the pix.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-29-2005, 07:43 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Happened to a buddy during a DE @ Gingerman. Same result. Spaghetti throttle linkage.
What's that hose shown in the picture? I'm not talking about the clutch cable.
Kevin L
'86 Carrera "Larry"
Old 08-29-2005, 08:02 AM
Nine9six's Avatar
Hmmm,
Drilling the CV joint fasteners for safety wiring may not be a bad idea!
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 08-29-2005, 08:49 AM
Sorry to see the damage. This sure is a warning for us to check the CV bolts for proper torque. There has been much discussion about proper torque and using Schnoor washers, etc.
Bottom line when you fix this use new bolts and washers, torque to specs and then check after fifty miles and recheck after a week or so.
The part number for the pivot pin is 914-301-307-00.
The lever is P/n 911-423-017-01.
You may need a easyout to remove the broken threaded end of the pivot pin from the transaxle.
The pivot pin is a porsche part. I replaced mine with a metric bolt and a bushing. Been good for a couple years.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 08-29-2005, 10:52 AM
ianc's Avatar
Yep, this just happened to me last Fri, but I guess I was the luckiest of all. I had just changed all the joints out a couple weeks earlier. Drove home the 16 miles on the freeway after work, then stopped at Trader Joes for some beer. I was about halfway home (about a mile from my house) and stopped at a light. The light changes, I put in the clutch, engage first and let out the clutch and nothing. I knew right away what it had to be. I pushed it over to the side of the road, went across the street to the handy dandy repair shop there, borrowed a 6 mm allen wrench and managed (with one hand) to get the joint back on the flange and all the bolts snugged up enough to limp home. Many choice indelicacies were uttered, shocking passers by. They had just backed out though and the threads weren't even damaged. Phew! The throttle rod got slightly bent when I pushed it to the side of the road, so the throttle stuck a little, but I bent it back. It had flung some grease around, so I took it back to my buddy's shop, loosened that joint again, fitted a new gasket, packed more grease, and torqued the absolute crap out of it. Those bolts are hardened, so don't be afraid to really tighten the bejesus out of them. I think you will strip out the allen cap before you break them.
I think it's important to check them again after a week or so since the gasket will slowly compress and take some of the tension out of the bolts. Why did they want to use a gasket there anyway? It makes no sense...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 08-29-2005, 01:01 PM
Zeke's Avatar
ianc
Wow. How many in one week? That's ridiculous. And, if you use safety wire, I would think that you would not want to put it on until you've retightened the bolts for about the 2nd time. You would only be holding them "loose" given the compression of the gasket. Time for some copper gaskets.
Old 08-29-2005, 01:20 PM
Send a message via AIM to jstein
Well, here's my fiasco.
Happened in the breaking zone before turn 1 at Gingerman a couple of weeks ago. The noise scared the crap out of me.
Same deal - half shaft fell off of the tranny side - decided to bounce around and bring the throttle linkage with it...
Output flange. Two bolts donated their threads to try and get me some decent lap times...
Bell crank pivot stud left some threads behind too. A right angle drill, Easy Out, and a prayer to the car gods got this bit of metal out.
Throttle "linkage" remains.
Even the pieces in the engine compartment were not spared...
Maybe it's time to start a support group?
"Hi, my name is Josh, and I didn't check my CV bolts"
1/5 '86 e30 "SHART" - 24hrs of Lemons veteran
'79 911 SC, webers, blah blah blah - The blue car (FOR SALE)
Old 08-29-2005, 01:45 PM
kqw kqw is offline
Alright, Alright, Alright...Already...
This evening I'm going to jack up the car and re-torque the CV bolts as 2 months ago I replace a CV boot.....
Thanks for the SCARE....I hate you guys...NOT.........
Another reason to get into the garage
The Fox
Carrera
Old 08-29-2005, 02:00 PM
Senior Member
ohecht's Avatar
Wow!, I had no idea it was that common. I R&R'd all the CVs a while ago and they were out for a clutch job, but I always use new bolts, Schnoor washers, and I do check them whenever I am under the car, which is fairly regularly. I always thought I would get some sort of warning before such a total failure without trying to spin out or something. Makes it kind of hard to trust the car again if I am afraid to hit the gas...
I might add red loctite to the threads for some piece of mind, and just take the time to get a good tool and angle on the bolts whenever I remove them...
Thanks for the parts numbers and the feeling that I am not the only one this unlucky.
KTL, the large hose is the vacuum hose for the brake booster. I had the CHT sensor wires (metal) wrapped around it and the axle must have caught those wires first and then ripped out the hose.
I think the grease was just after the catastrophic failure, since I would have noticed it burning off the exchangers if it was flinging for any period of time.
Olivier
Olivier Hecht
1982 911SC
Old 08-29-2005, 04:08 PM
MovOvr1's Avatar
have people safety threaded these for added security? Does anyone sell the bolts predrilled? That would be well worth doing.
Glad to here that everything is replaceable and there wasn't any further damage.....or carnage.
B
Brian
BLK 79-930
Old 08-29-2005, 04:35 PM
these thread make people like me buy a scissor lift, because if you read enough, you'll be checking everything all the time. Jack it up after every drive and check the baby just so you can sleep well at night.
I think I'm about one more "check this or you car will die thread" away from getting a lift.
put me down for one that's never put a wrench on my half shafts
Old 08-29-2005, 04:42 PM
randywebb's Avatar
There have been maybe a dozen reports of these things coming loose. OTOH, there are several thousand people on the bbs, so...
I tried to start a thread to findout _why_ they coming loose - of the few who posted it was:
a. not cleaning grease off the threads before installation
b. not torquing them down correctly
c. re-using old Schnorr washers instead of getting new ones (which have sharp teeth to bit into the substrate metal)
You can buy cap screws from specialty firms that have holes for safety wire manufactured in them. Be sure to get the right strength class....
Drilling your own holes is a lot of work, and I'd don't like hte idea of introducing stress risers where the cap might break off -- but Jim Sims said it should be ok, and he should know.
Hit the search engine and you'll find a lot of info on this. The above is a summary.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 08-29-2005, 05:54 PM
What are the torque specs for these bolts and is there a certain pattern to follow when checking these bolts ?
77S
04 Titan
03 Xterra
Old 08-29-2005, 07:04 PM
iamchappy's Avatar
I mark my bolts with a paint line and inspect often. I had a CV come off on me once. Without safety wire at least I can tell with a quick look if they have loosened up.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 08-29-2005, 07:17 PM
