Case through bolts - what's the original finish?
I've seen the threads where folks are doing yellow zinc on them. Or sometimes just on the acorn nuts and washers. Others I've seen where the heads are dark, like black oxide. Others I've seen are bright (perhaps clear zinc?) The ones in Wayne's rebuild book just look like he cleaned them a little and reused them. They certainly don't look replated.
Obviously they can be plated, and I've read some of the threads about yellow zinc and cad. Question #1 How did they come from the factory? The heads on mine ('83 SC--believed to have never been apart) had a dark surface with very light rust, with the nuts and washers a sort of dull gray, with a hint of yellow on the nuts. Question #2 If I don't send them out for zinc plating, what's another good option? |
We've done customer's sets in both black phosphate and yellow zinc.
First is black phosphate with yellow cadmium acorns and second set is all yellow zinc. ![]() ![]() ![]() ![]()
Tru6 Restoration & Design |
undervalued member
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Nice looking parts Shaun. We do some parkerizing on some of our products. Have you ever parkerized the washers and nuts as well? Any reason not to other than aesthetics?
Chain fence eating turbo
Good job guys of NOT answering the OP's question...
The Dude abides...
OP doesn't seem to mind...don't be a Ricardo...
Steve '87 Targa Granite Green |
Well, I'm not going to complain about the response from Shaun, since I found it useful, even though it was a bit off topic. The other response I'm still trying to figure out. Yellow zinc parts on a bench? Unless those are NOS parts, doesn't tell me much.
But yes, I'm still interested in finding answers to my two questions. So, anyone know what the original finish was? |
Jameel, I can't say with 100% certainty, but I think the original case bolts were simply black oxide, early ones anyway. I say this because I've never seen any evidence of any type of plating on motors I've pulled apart. Or on customer bolts sent in to be redone. We use black zinc phosphate because it lasts longer though isn't close to zinc chromate.
If you wanted a factory look that would last a very long time, I would opt for black zinc chromate. I know that SWB fan straps, early front torsion bar adjusters and brake line holders were black zinc phosphate as well as early lock, wave and Schnorr washers. We always buy new and replate for customers...I consider them one-time-use only items, no sense in putting your car back together with worn out washers. Front hub bearing caps and shift rods are grey zinc phosphate. Washers and nuts were yellow zinc so that's what we do, or yellow cad. ![]() ![]()
Racer
I'll add more to thread....
I had a case thru bolt break on my 964 3.6L race motor. It happened to be one that kept oil in the case. What a mess considering I had over 4 gallons of oil in the oil system. Anyway, the engine builder and I discussed it and decided to replace the broken case thru bolt with an ARP thru bolt. When the engine was rebuilt, the rest of the engine's thru bolts were replaced with ARP. Problem solved....
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Racer
Thanks for the further info Shaun. Good to know.
