djcdmv's Avatar
Oil pressure stuck at 4, not pegged at 5 (searched)
Ever since I got the car last summer, the druck press gauge has been stuck at 4 as soon as the key turns in the ignition. I found a few threads, so I checked all the connections. Funny thing is, when I disconnect the wires from the sender, the needle pegs at 5 (like most say happens when it is a wire/ connection problem). When I reconnect, it drops down to 4, and doesn't go down until car is off. Any ideas? Thanks in advance.
Dave
Black 1985 911 Carrera M491
Old 04-02-2011, 01:13 PM
Senior Advisor
James Brown's Avatar
sounds like the sender is bad, ground the wire and see what happens.
08 Cayenne Turbo
Old 04-02-2011, 01:39 PM
6 cylinder symphony
Disconnect the wire to the sending unit. Using alligator clips - attach the positive lead to the sending unit. Attach the black lead to ground. Set the voltmeter on OHMS - you are looking for a resistance reading. Start the car. If the resistance changes with RPM - it's the gauge. If resistance doesn't change, it's the sending unit.
Unplugged - resistance is infinite, which is why the gauge pegs at 5.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 04-02-2011, 02:25 PM
where is the location of the oil press sender??? Im a rookie with a new toy....
Im reading a lot so I want to make it works like new
Old 07-22-2012, 11:19 AM
Germanator's Avatar
check this posting, everything you wanted to know and pictures:
Question On Oil Pressure Sender
Old 07-22-2012, 12:52 PM
what is the ideal oil press on 900rpm cold car and press about 2,500rpm in 4 or 5 gear??
Old 08-22-2012, 04:40 PM
schumicat's Avatar
rule of thumb with oil at operating temp is 1 bar per 1000 rpm. when cold it could be 3-5 at idle, depending on how cold it is and how thick oil is.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-22-2012, 06:34 PM
Banned
Old 08-22-2012, 07:00 PM
