petercory
CV Joint Question
The CV joints on my Turbo look were attached using 10 X 60mm socket head cap screws; no half moons, schnoor washers or inner lids were in place, the joints were bolted directly to the transaxle flanges. Should I reassemble them the same way or should I at least add the inner lids; if so, will adding the inner lids affect the rear camber settings?
Old 10-05-2012, 08:09 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Check out posts on this by Grady Clay - the following link is quite helpful
Reconstructing Constant Velocity (CV) Joints
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 10-05-2012, 09:24 AM
petercory
Thanks, I did previously read that post, however it applies to the earlier models that used the 10 X 50mm bolts and had a gasket between the CV joint and the transaxle flange, not the later or 930 CV Joints that came from the factory with 10 X 60mm bolts and without half moons or schnorr washers and do not use a gasket between the CV joint and transaxle flange.
Old 10-05-2012, 10:21 AM
Have you looked at the parts diagram in PET? Should at least indicate what the proper parts are...
'90C4
Old 10-06-2012, 08:30 AM
petercory
Yes, I've looked at the Pet parts diagram and compared them to posts on this subject that refer to the fact that 108 mm joints are installed without Schnorr washers or half moon clips (as pictured); however none of the posts refer to the CV Joint caps/lids. My car didn't have caps/lids in place and the bolts were still properly torqued after 30,000 miles of hard use, thus I am questioning the need for the caps!!!
Old 10-07-2012, 05:10 PM
