Question Can't remove pulley bolt!
I decided to try and tackle the pulley seal replacement on my '82 911SC. Semi-dropped the engine, but I can't get the pulley bolt off.
I first tried my old, crappy 1/2" impact gun, no dice. Went out and purchased a higher quality one, Craftsman Pro rated at ~500 ft/lbs, and it still won't move. Tried a new air hose and connectors, thinking maybe the line was restricting the air flow, no improvement. It's a 20 gallon tank @ 100 psi, and it will run the gun for plenty of time before the pressure drops enough to kick on the compressor, so I think I have adequate air.
The car is on jack stands, wheels in the air, trans coupler removed (left in first gear for coupler re-alignment), so my guess is that a big-ass breaker bar is just going to turn the engine over, backwards, even if I have somebody hold the brakes.
Any ideas for what to try next?? I'm assuming heat and/or PB-blaster type tricks are useless on this kind of bolt?
Old 08-25-2012, 11:16 PM
wasserkuhl's Avatar
Place it in 5th gear, not 1st.
Guarantee it will work with it in 5th......
Old 08-26-2012, 02:27 AM
Do you know anyone with an Ingersol Rand impact wrench you can borrow? Seriously...I've loaned mine out when "others" couldn't get the task accomplished. Or, can you get a 3' brealer bar (section of pipe) in place...I've also seen a 3' pipe accomplish what my I/R couldn't...good luck!
Old 08-26-2012, 04:34 AM
Try raising the pressure to 125 psi. That should break it loose.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 08-26-2012, 05:09 AM
Ingersol Rand 1/2 impact gun,
a good impact socket.
Turn the compressor to 125 psi, as high as it can go
Flame the bolt,
and it will go.
Forget that Pro Rated Sears Brand gun. It is crap. Buy what the Pros buy, an Ingersol Rand.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-26-2012, 05:19 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pulley Bolt.
Try this with a 3 foot pipe extension on your ratchet + PB Blaster.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-26-2012, 06:54 AM
Just for clarity, I'm talking about the CRANK pulley bolt, not the fan pulley bolt shown above.
I'll try breaker bar with cheater pipe, 5th gear.
On the impact gun, I know IR's are the way to go. But I need an impact gun infrequently and was hesitant to pay the IR $$$. Sears is going back.
Old 08-26-2012, 08:14 AM
Garage Queen
PorscheGAL's Avatar
I just did this yesterday. Use the breaker bar with pipe. I had to use a 3' pipe and it broke loose.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 08-26-2012, 09:42 AM
Yup. Mine just came loose as well. About 40" of cheater/breaker bar, 5th gear, e-brake, and pretty much leaning into the bar.
Here I thought I was doing things the easy way with the rattle gun, but it turns out old school saved the day. Too long of a lever on too small of a bolt, then keep applying more and more force until something gives.... "POP!" I immediately knew that I either achieved my objective or broke something costly... Fortunately, it was just the bolt popping loose.
Thanks to all who responded!
Old 08-26-2012, 05:03 PM
83 911 Production Cab #10
JJ 911SC's Avatar
I think you did yours with the engine out, lock the flywheel?
Who Will Live... Will See
Old 08-27-2012, 02:22 AM
