Pelican Parts Vendor
BRAIDusa's Avatar
Originally Posted by Toby930 View Post
What color did that customer use to match the center caps against the black center? And how did they paint the contours silver?
Look really nice!
Where can you order the shorter studs?
Cheers
/ Tobias
And I quote:
"When I painted the wheel caps I didn't have any satin black, so I painted them matt black, after they were dry I rubbed off the logo carefully then to get the satin finish I rubbed them with my bare hand to "polish" them. Worked well."
Pelican has the shorter studs. Just search for a 84 911 Carrera.
Paul Eddleston
BRAID Wheels USA
Team Illuminata Motorsport
Old 08-26-2015, 03:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #341 (permalink)
I just checked availability for 11"x17"s but they show 10.5" to be the widest. I saw in a previous post that you said to call Pelican. Is that still the case?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 08-26-2015, 09:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #342 (permalink)
BRAIDusa's Avatar
Try these:
Pelican Parts - Product Information: PEL-BZ11X17-RSR
Pelican Parts - Product Information: PEL-BZ11X17-STD
You shouldn't have to call.
Paul Eddleston
BRAID Wheels USA
Old 08-27-2015, 08:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #343 (permalink)
I see there is some interest in how the centre caps were done, so I will attempt to explain in more detail.
I started with the Silver Centre Caps part no: 901 361 032 00.
I first wiped the caps clean with a clean cloth. I used a micro fibre cloth.
I then painted them with 2 to 3 light coats of Killrust Matt Black allowing a minimum of 16 hours between coats, as per the paint instructions. Too thick and it may cause problems when exposing the logo, although the first cap had about five coats while experimenting getting the appearance right.
When dry I wet a paper towel with metholated spirits the lightly rubbed (and small areas) over the logo to expose the silver underneath. Metho served to soften the paint enough to rub off. Turpentine may be a bit strong and remove the wrong areas, although I didn't try, again because I didn't have any available. The paper towel is abrasive enough to remove the desired areas.
Now the fiddly bit….For the "fine detail", such as the shield edge, I used a scalpel (hobby knife) to gently scrape the edges and some high points that were cast at a different height the rest of the crest. You'd be amazed how uneven the crest is. A gentle wipe with the paper towel with metho every now and then, to remove "debree" and keep the paint "soft". This stopped the paint from chipping and coming away from areas that I want to keep covered in paint.
When the crest is finished, wipe with the clean cloth then rub over the whole surface, in a circular motion, with the palm of the hand to remove the matt finish. Again don't rub too hard. The idea is to use the skins natural oils to "polish" the cap. Rub too hard and it's start again !! Check against the wheel for the desired "satin" finish.
Once happy that the finish is matched and even, again wipe over with the cloth.
Clip into place, ensuring the shield points to the valve cap (for all the concours people out there). For some reason it is actually aesthetically pleasing.
Job done !
Cheers
PS: After I had finished, thinking I had come up with something different and feeling proud of myself, I found somebody on PP had already done the same thing. Just proves that nothing is new.
Last edited by OZ930; 08-27-2015 at 08:15 PM.. Reason: centre cap part number added
Old 08-27-2015, 04:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #344 (permalink)
Great results! Sorry if I missed it, but which cap served as the basis for your hand rubbed creation?
My Braids are coming and I want to be ready.
Thanks!
Old 08-27-2015, 05:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #345 (permalink)
Sorry OldSpool87, I missed that, so I have amended the post,
Old 08-27-2015, 06:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #346 (permalink)
Originally Posted by BRAIDusa View Post
All the silver accents on our BZ range, outer rim and/or petals is anodized. This is not just the regular anodizing but the "soft" style of anodizing used on the original wheels. It is not easy to achieve but ours is very "original looking".
Hi Paul,
Are the RSR finish BZs sold by Braid UAS finished any differently to those supplied by Braid in Spain?
Put another way: If I buy in Europe are they anodized too, or painted soft silver?
Thanks, James
_________________
James
'74 914/6 3.0 Texas GT
'73 911 2.7 RS Replica LHD
'72 911 2.4 E RHD (Sold)
Old 10-31-2016, 11:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #347 (permalink)
BRAIDusa's Avatar
Originally Posted by 23e Heure View Post
Hi Paul,
Thanks, James
All the same James, but, of course, we'd prefer you to buy them through our hosts.
There will be 21% VAT in addition as you are still in the EU.
Paul Eddleston
BRAID Wheels USA
Old 10-31-2016, 11:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #348 (permalink)
sbrown.nw's Avatar
Resurrecting an old thread here. I have these for sale if anyone is interested:
new Braid BZ RSR 17" x 8" & 9" rims, correct for G body cars, big discount, no tax
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 10-01-2020, 09:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #349 (permalink)
